SnowDrifter Posted April 9, 2012 Report Posted April 9, 2012 Here is the issue with bass boost It is like a secondary gain, but only at a certain frequency - typically 45hz So you set your gain how it should be. All is good. Then you turn up the bass boost. Now whenever you play a note at the bass boost frequency - it clips. But it's only at that frequency. Now, if you use the dd-1 to set the gain: it is set via a 40hz tone, but the bass boost amplifies 45hz with a rolloff above and below. It breaks down like this: 40hz is lower than 45hz Bass boost will amplify 45hz more than 40hz 40hz won't clip, but 45hz will So really, the only way to accurately set bass boost is with an oscilloscope. It's not bass boost that mystically causes clipping, it's people not knowing what it does and not setting gains to compensate. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
TeamHT Posted April 9, 2012 Report Posted April 9, 2012 Bass knob is not bass boost. Tell me...does this smell like chloroform to you?
Decaf Posted April 9, 2012 Report Posted April 9, 2012 will, the only reason ever to use bass boost is if you have a DROP in RESPONSE around where the boost is and you have testing equipement to verify how much you can boost without introducing clipping plain and simple leave it off, set gain correctly so all notes passed through amp are amplified evenly otherwise you are just ruining the balance of the sub by boosting
will77530 Posted April 10, 2012 Report Posted April 10, 2012 will, the only reason ever to use bass boost is if you have a DROP in RESPONSE around where the boost is and you have testing equipement to verify how much you can boost without introducing clipping plain and simple leave it off, set gain correctly so all notes passed through amp are amplified evenly otherwise you are just ruining the balance of the sub by boosting thanks decaf
BassMunky Posted April 10, 2012 Report Posted April 10, 2012 why did they even put it on the amp than the bass knob like the one i have on my rf1500 amp. It seem uselesss to me only to use on rock songs. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
ANTMANTHAKID305 Posted April 10, 2012 Report Posted April 10, 2012 holy jebus im rolling.... this is funny bass boost can be used for rock or quieter music, you should NEVER need it for rap music, EVER. you will find some companies limit it to 6dB to PREVENT user error because people think a knob magically makes bass better. Bass Boost is a One Band EQ, usually centered at 45hz. Why, because kick drums are right there and a lot of rap beats fall there. The gain on the amp boosts all frequencies the amp plays evenly, using bass boost will ruin that evenness by boost only a small section of the overal signal it amplifies. Example, song with 30hz note, 45hz note, 60hz note all even dB signal before being amplified. If you choose to use bass boost you just ruined that evenness of sound and can easily clip the amplifier. If you use the DD-1 to set gains with a bass boost knob you will end up with quieter lows and high bass, but loud mid-sub bass(40-50hz), this is something undesired. THANKS I NEEDED THAT HONESTLY I RIDE AROUND ALL DAY LISTENING TO MUSIC AND WORK AT A CAR AUDIO SHOP AND NEVER KNEW THE ACTUAL PURPOSE OF BASS BOOST YET I HAVE THE AMP AND THE KNOB ON MAX. I'VE SEEN NOTHING WRONG WITH MY SETUP, BUT I INTEND TO RETUNE MY THE FREQUENCIES SINCE I WANNA HIT REALLY DEEP LOWS I'LL TRY TURNING IT DOWN ALSO. THANKS FOR THE KNOWLEDGE IT WILL BE PASSED ON. QUICK QUESTIONS I PRAY YOU KNOW... I JUST BOUGHT A PAIR OF BRAND NEW CVX 15'S AND I HEARD ABOUT THE BREAKING IN PERIOD, MY QUESTION IS... IS IT REALLY NECESSARY TO WAIT AND IF SO HOW LONG SHOULD I WAIT BEFORE I CAN FEED THEM WHAT THEY'RE BEGGING ME FOR??? ALSO IS IT DUE TO ME HAVING MY BASS BOOST ON THAT WHEN I PLAY THE PUT ON INSTRUMENTAL THE LAST NOTE YOU BARELY HEAR UNLESS YOUR INSIDE MY CAR??? LAST BUT NOT LEAST WHAT IS A PERFECT TUNING FREQUENCY TO GET THE MOST OUT OF MY CVX 15'S??? THE SETUP IS A BRUITS 2400.1 SUPER CLASS D AMP WITH A SUPER BASS PROBOX HAVING 3.25 CUBIC FT PER CHAMBER IN A 2001 VW JETTA WAGON.
Nikitaaa Posted April 10, 2012 Report Posted April 10, 2012 holy jebus im rolling.... this is funny bass boost can be used for rock or quieter music, you should NEVER need it for rap music, EVER. you will find some companies limit it to 6dB to PREVENT user error because people think a knob magically makes bass better. Bass Boost is a One Band EQ, usually centered at 45hz. Why, because kick drums are right there and a lot of rap beats fall there. The gain on the amp boosts all frequencies the amp plays evenly, using bass boost will ruin that evenness by boost only a small section of the overal signal it amplifies. Example, song with 30hz note, 45hz note, 60hz note all even dB signal before being amplified. If you choose to use bass boost you just ruined that evenness of sound and can easily clip the amplifier. If you use the DD-1 to set gains with a bass boost knob you will end up with quieter lows and high bass, but loud mid-sub bass(40-50hz), this is something undesired. THANKS I NEEDED THAT HONESTLY I RIDE AROUND ALL DAY LISTENING TO MUSIC AND WORK AT A CAR AUDIO SHOP AND NEVER KNEW THE ACTUAL PURPOSE OF BASS BOOST YET I HAVE THE AMP AND THE KNOB ON MAX. I'VE SEEN NOTHING WRONG WITH MY SETUP, BUT I INTEND TO RETUNE MY THE FREQUENCIES SINCE I WANNA HIT REALLY DEEP LOWS I'LL TRY TURNING IT DOWN ALSO. THANKS FOR THE KNOWLEDGE IT WILL BE PASSED ON. QUICK QUESTIONS I PRAY YOU KNOW... I JUST BOUGHT A PAIR OF BRAND NEW CVX 15'S AND I HEARD ABOUT THE BREAKING IN PERIOD, MY QUESTION IS... IS IT REALLY NECESSARY TO WAIT AND IF SO HOW LONG SHOULD I WAIT BEFORE I CAN FEED THEM WHAT THEY'RE BEGGING ME FOR??? ALSO IS IT DUE TO ME HAVING MY BASS BOOST ON THAT WHEN I PLAY THE PUT ON INSTRUMENTAL THE LAST NOTE YOU BARELY HEAR UNLESS YOUR INSIDE MY CAR??? LAST BUT NOT LEAST WHAT IS A PERFECT TUNING FREQUENCY TO GET THE MOST OUT OF MY CVX 15'S??? THE SETUP IS A BRUITS 2400.1 SUPER CLASS D AMP WITH A SUPER BASS PROBOX HAVING 3.25 CUBIC FT PER CHAMBER IN A 2001 VW JETTA WAGON. How long though that did it take you to realize your caps lock was on? 2007 M/T Honda Civic Coupe EX (4) Sundown Audio X-8's (2) Ampere Audio 3800.1's (3) Stinger SPV-44 Batteries (1) Mechman 240 3:1 Ratio 4th order sealed from the trunkTEAM NWSPLBest termlab scores to date in Honda trunk:151.7db legal (official) IASCA trunk 3 classBest termlab scores to date in my walled Subie:152.9db legal (unofficial) IASCA advanced 2 class155db outlaw
TeamHT Posted April 10, 2012 Report Posted April 10, 2012 And is he pulling a carshateme liking his own status? Tell me...does this smell like chloroform to you?
Ecco Posted April 10, 2012 Report Posted April 10, 2012 He's not exactly making a great first impression on me..
ANTMANTHAKID305 Posted April 10, 2012 Report Posted April 10, 2012 Look i did it for attention cuz it seems when i post something people look at it yet the don't reply. I just need a lil help that's all... do you know anything about what i'm asking or do i have to go elsewhere???
