SnowDrifter Posted April 11, 2012 Report Share Posted April 11, 2012 Ok, so I am getting ready to pull the trigger on a Fi SP4. But I have something on my mind... The specs on Fi's site say this: DUAL 1 | DUAL 2 0.65 Ohms/coil | 1.27 Ohms/coil I want to have it wired to .5 ohms (crescendo 3500) but I have a concern: If I get the dual 1 I am worried about the amp seeing 1/3 ohm instead of a half ohm because of the .65 ohms/coil as per the specs, or would I be OK because it's a dual 1 ohm coil? Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
t-money Posted April 11, 2012 Report Share Posted April 11, 2012 i would think after impedence rise you should be fine but thats just my 2 cents Quote 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056 Link to comment Share on other sites More sharing options...
baaudio Posted April 11, 2012 Report Share Posted April 11, 2012 go dual 2 then and amp will see .5-.7 wired in parallel. that'd be a safer bet anyways man Quote Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k Link to comment Share on other sites More sharing options...
Joe X Posted April 11, 2012 Report Share Posted April 11, 2012 Re is the DC resistance of the sub not the impedance, any sub measured with a multimeter will show a lower value than the impedance rating. Quote Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 11, 2012 Author Report Share Posted April 11, 2012 Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
bkolfo4 Posted April 11, 2012 Report Share Posted April 11, 2012 Re is the DC resistance of the sub not the impedance, any sub measured with a multimeter will show a lower value than the impedance rating. OP - why did you bump the thread? Joe X provided you with the correct answer. The sub is dual 1 ohm. Quote Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 11, 2012 Author Report Share Posted April 11, 2012 I get the nominal resistance will always be lower than rated. I am just nervous about having 1/3 ohm nominal. Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
dolarbilz Posted April 11, 2012 Report Share Posted April 11, 2012 If nervous get dual 2. Play it safely.instead of worrying about what if's Quote Link to comment Share on other sites More sharing options...
jrchevy87 Posted April 11, 2012 Report Share Posted April 11, 2012 (edited) I would be too. With the dual 2 ohm parallel u will see .6 to .7 ohms which is close enough imo Edited April 11, 2012 by jrchevy87 Quote Jeep Wrangler TJ Hardtop Build Link to comment Share on other sites More sharing options...
MrSkippyJ Posted April 11, 2012 Report Share Posted April 11, 2012 If you want .5 ohms get the d1 option. That simple. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
