So for every box I've built for myself, I've used liquid nail to bond, and seal. I feel as though it doesn't work too crazy well. Is there anything else that may be better ? I use heavy duty liquid nails.
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
I use Titebond 2. The blue stuff. Hasn't failed me yet. If you have big gaps, seal them up with caulk.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
my last box i used titebond II for all joints...and then I used caulk on all inside corners where 2 pieces met...to make sure it was air tight in case the titebond II wasnt put on thick enough or something...it seems to me that this is holding up just great so far...some people will fiberglass resin the inside of the box for strength and to seal it up better
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
This topic has been discussed in many treads if you do a search. You will find that there are many opinions. Personally I have been using Liquid Nail since 1988 with no problems. I have also used plain would glue and silicon to seal the corners.
titebond is an actual wood glue. bonds wood together.
liquid nails is just an all purpose glue. good for sticking shit together but not bonding it.
It seems the majority on forums, as well as myself personally do use the Titebond II wood glue. If you spread it evenly and keep the pieces tight together until it dries, it has always seemed to work just fine. I typically caulk all of the inside seems regardless just in case. Overkill isn't really a bad thing here.
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
yeah but the search engine here it aint all that great, cuz i be searching stuff that i seen a few days ago and it never finds it, it sucks
REFF'S
My link
EBAY
http://feedback.ebay...ck&myworld=true
I love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
Liquid nails sucks. I use titebond 2 wood glue and latex caulk on the inside seams. Silicon sucks too. Caulk is the best in my opinion that with wood glue. Great bond and airtight. Silicone works ok but over time I've seen it peel off easy.
I've like liquid nails (wood). I use wood glue to put the edges together then on the inside of the box I run a bead down the joints. Then I come back overit with my corner tool I made and smooth it out. Not sure if most people know this... but Liquid Nails for Wood has resin in it.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
titebond II or III for me.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 2379 Guests (See full list)
