Kenne Bell 2010 Mustang GT: Speed (slow) and Sound Build
What kinda load you got at the amps... Is the subsonic correct ?
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
I sense a troll.......
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Just checked speaker wires, its right, each d2 sub is wired to one ohm on its own amp, not strapped. Gains matched with CC-1.
Going out to recheck phase right now.
You said you had a gain issue right?
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
your box is not sealed into the cab, try turning it around and firing it back if possible, in my grand am, i lost tons of output firing forward not sealed off, then turned it around and mediately gained an incredible amount of dbs. you could easily be havin some sort of cancellation issue because of that.
and if the voltage is not dropping much, you could have some very high rise
