BassBarbies Ford Edge Build Sundown,Shok, Project DB, Pioneer
My first show ever was an Iasca even in Marysville, WA at soundwerks was just a 1x points event and I did well with the 8s I came home with first in stock 1-260 wagon should have been in rookie but my ports were not a prefab port they are custom. So that was a bummer but still happy with first in the class i was put into I did a 142.5 at this show.
Here is a pic of the show im in the middle Im not that short lol the guy to the left is 6'9"
I love how you are the only one that actually looks happy.
They get loud to the ear and flex the shit out of my ride but meter wise only did a 147.2 db @43 hz
What is your 4th tuned to now? One thing I have noticed with no wall 4ths is that they tend to peak lower than you really want for numbers, but they sound amazing on music and move a ton of air.
Imo .. Because i built 4 th orders before , but u should turn the subs around and leave middle one the same.. Just a suggestion
If you do this, make sure that you wire the middle sub out of phase so that it will move the same direction as the others and not fight them.
Before scrappin' the idea already, play around with the port, higher tuned might give you gains.
SMD Super Seller
My Feedback Thread
it sounds like a 150 plus for sure just meter is disapointing. im looking into a setup that will do well number wise and daily
Don't Let the Pretty Face Fool You, I Roll Like a BOSS :D
2008 Ford Edge SEL
Pioneer Avh-4400 Head Unit
2 Sundown Z V.3 12"s
Mechman 270 Amp Alt Externally Regulated
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Lots of Stinger Road Kill Deadner
152.1 DB Legal TL Score (for now)
Build Log
http://www.stevemead...dge-sa8s-build/
How much watts are the 8s getting a piece? Also, I'd experiment with reverse mounting them, and having a 15" round flared port.
(just looked earlier) If you are putting 7,000 watts to the 8s then you have something working against you as far as hitting high numbers and that's going to be cabin volume. You have a lot of interior volume that you are trying to "pressurize" in order to hit a high number. There's a few options that can be done to stay in that class, and that's experimenting with a long flared round port, or having larger cone area speakers (understanding that this may move you out of the given class), or swapping the sound into the Civic (smaller interior volume).
The other option is to build a bigger box with all 8s and the port firing upwards, as long as it's under the rear window line. The reason for the bigger box, or a raised box, is to cut down on the given volume of the cargo area so that you only have the space above the box and the cabin seating area to "pressurize" with sound.
Oh, btw with that kind of power you'd be seeing around 155's in a smaller vehicle.
Bass Music Producer • Photographer • Graphic Designer
Deep Sector Boom...
moving my gear to my civic would be pointless as there are too many small cars with bass its easy. I did a 144.9 on 3k with 2 8s so im sure its the 4th order design. Im going to try 2 sundown z v.3 12s they seem to do well for spl
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
But don't give up on the 8s, or at least put them on the doors and add the 12s to the setup.
But if you go with the 12s alone, I think you'd be losing cone area.
Deep Sector Boom...
