BassBarbies Ford Edge Build Sundown,Shok, Project DB, Pioneer
I can almost guarantee that there is not 7000w clamped power going to those subs. If there were then they would blow themselves out of the box. I would be shocked if there is more than 4-5000w clamped power at the very most.
way to be a debie downer. lol. Have you tried what ray suggested? Stuff the seal section with polyfill? Also try more of a round port, see if you can do a interchangeable round ports with aeros, 4th orders require alot of testing and tuning, maybe tune a little higher for the spl port. Are you competing in iasca? If so i remember talking to the judges they have a rule is as long as you are under 25in you are golden, i ask them about the window line, and they said its just 25in.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Sometimes I said I might not like the setup in one of mine just to give me an excuse to get my hands dirty for a new build. Its like a drug not just the odyssey for harder and louder hits but the journey of the blood sweat and tears that gets you there. I am for sure tuned into this keep up the hard work numbers will come.
Not being a downer, just being realistic. Not sure what her final ohm load is at the amp, but with 4th order comes a decent amount of rise.
he's not being a downer there's just no way they are getting 7000watts.
edit: Ninja'd lol
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
That's false. Not much in 4th orders.
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
She's using a Sundown NS-1. She may not be putting 7000 to the subs.
Here's a user's clamp test of the amp - http://www.caraudioclassifieds.org/forum/general-car-audio-discussion-questions/116797-sundown-ns1-clamp-test-results.html
His results:
starting voltage 14.8v
voltage drop 12.7v
wired to .5ohm rising to 1.39ohm @ 45hz
rail voltage 97.3vac
amperage 70amp
total output = 6811w
And he did "highest spl of the day was 156.1 sealed at 45hz with the 8 sa15 powered by the 1 NS1"
side note to show 8s handling 7k total power
7000watts on 8 Sundown 8s
http://www.youtube.com/watch?feature=player_embedded&v=50WaWardmJw
Bass Music Producer • Photographer • Graphic Designer
Deep Sector Boom...
:popcorn:
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
I am curious what she's giving the subs though but...
From Sundown's website - NS-1
Rated power output
----RMS power, 2 ohm linkable/dual mono 13,000W x 1CH
----RMS power, 1 ohm mono 6500W x 1CH ----RMS power, 2 ohm mono 3300W x 1CH
----RMS power, 4 ohm mono 1800W x 1CH Low pass frequency crossover 35Hz~250Hz Subsonic filter 10Hz~50Hz Bass boost @ 45Hz 0~9dB Phase shift control 0~180 degree Frequency response 10Hz~250Hz (+/- 1dB) T.H.D @ 4 ohm <0.1% Efficiency @ 4 ohm 86% Fuse rating 650A (external type fuse) Input Sensitivity 0.2V to 6V (+/- 5%) Dimensions 12.20(W) x 2.68(H) x 27.56(L) inches
Deep Sector Boom...
So when I clamped a pair of dc 3.5ks starting at .5 ohms strapped and rising to 8 ohms in a 4th I was mis reading the meters? Show me your proof to prove me otherwise. I know that all boxes are going to act differently, but when I was talking with mike singer before I designed my 4th, he told me to expect 2-4x rise so I would be good wiring low. I will take his word over yours.
Seeing how as I'm confident you won't believe me, take a look at Ray's first comment on page 15, post 291.
