kingsuv Posted June 9, 2012 Report Posted June 9, 2012 Simple little build for the younger brother of the Camaro owner these past few nights. They are all finished and I'm waiting for the truck to come back to hang them. The plan was to add in a pair of 8's to the rest of his system. Liking how my truck sounds and how well the camaro gets it, it was time for him to step up his game. He's running a pair of Kenwood 5.25 and is adding the Rockford P2's Kinda glad they were 5.25 as making room for bigger would of sucked. Time to get to cutting the rings to mount these. Outter ring is for the sub and the inner ring is to cradle the magnet in the door. Now to cut out for the 8. No pics of the metal cutting, but all I basically did was stack rings to match the depth needed for the subs and bolted them to the doors. Now to make a flush ring. Mounted the sub so I can find where the 5 will sit under the flush ring. Once I like the layout, it was time to make it final. All i did was glass and mat in the holes to give support to bolt the pod to the door. Resin doesn't stick so well so it's how I made it secure. Next was to make the flush cover ring. this was my 1st idea, but just as I was about to begin, i switched and started idea #2, bout half way through, I ditched it and went back to idea #1. I spray glue my fleece over the flush ring then resin it together without going down the sides. once it's dry, i then spray glue the fleece to the tape and use it to hold down the fleece while I resin it up. once I have 2 layers on top, I pull it and do a layer on the inside. Trim off the extra material and then add a little filler to smooth out the bumps and she's almost done. Wrapped it up nice and shes ready to go on the truck Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it.
Azagtoth502 Posted June 9, 2012 Report Posted June 9, 2012 pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
sprkn_ranger Posted June 9, 2012 Report Posted June 9, 2012 That looks really good man! Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
Nasty1 Posted June 9, 2012 Report Posted June 9, 2012 Bad Ass job man you made it look real easy. Is the 8 free air or is there an enclosure behind ??? 2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz 19 cubes net 245sq in of port Sundown 3500 @ .7 Ohm Sundown 100.4 Rockford Fosgat Power Series 5.25 Dash 6.5 Kicks 8 Coaxils Doors 250 mechicman alt 1 red top under the hood 2 yellow tops in back big 3 with 1/0 knukonceptz wire 3 runs of +/- 1/0 knukonceptz wire IT LBS
kingsuv Posted June 9, 2012 Author Report Posted June 9, 2012 trying the door as the airspace on this one. Can seal it up real easy if it doesnt work Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it.
RooTxBeeR Posted June 9, 2012 Report Posted June 9, 2012 Dude, if I shipped my door panels to you, could you make some magic happen? On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Nasty1 Posted June 9, 2012 Report Posted June 9, 2012 Whats the cross over points for the 8s??? 2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz 19 cubes net 245sq in of port Sundown 3500 @ .7 Ohm Sundown 100.4 Rockford Fosgat Power Series 5.25 Dash 6.5 Kicks 8 Coaxils Doors 250 mechicman alt 1 red top under the hood 2 yellow tops in back big 3 with 1/0 knukonceptz wire 3 runs of +/- 1/0 knukonceptz wire IT LBS
IH8PunkRok Posted June 9, 2012 Report Posted June 9, 2012 at first i thought you meant an 8" woofer and i was unimpressed but then i saw a sub. changed my mind real quick -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
dolarbilz Posted June 9, 2012 Report Posted June 9, 2012 Looks good.so is that 8 used as midbass or sub?
Ray Posted June 9, 2012 Report Posted June 9, 2012 Nice job billiam. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
