8's in the doors of a Tahoe? sure why not. Rebuild time.
Simple little build for the younger brother of the Camaro owner these past few nights. They are all finished and I'm waiting for the truck to come back to hang them.
The plan was to add in a pair of 8's to the rest of his system. Liking how my truck sounds and how well the camaro gets it, it was time for him to step up his game.
He's running a pair of Kenwood 5.25 and is adding the Rockford P2's Kinda glad they were 5.25 as making room for bigger would of sucked.
Time to get to cutting the rings to mount these.
Outter ring is for the sub and the inner ring is to cradle the magnet in the door.
Now to cut out for the 8.
No pics of the metal cutting, but all I basically did was stack rings to match the depth needed for the subs and bolted them to the doors.
Now to make a flush ring.
Mounted the sub so I can find where the 5 will sit under the flush ring.
Once I like the layout, it was time to make it final.
All i did was glass and mat in the holes to give support to bolt the pod to the door. Resin doesn't stick so well so it's how I made it secure.
Next was to make the flush cover ring. this was my 1st idea, but just as I was about to begin, i switched and started idea #2, bout half way through, I ditched it and went back to idea #1.
I spray glue my fleece over the flush ring then resin it together without going down the sides.
once it's dry, i then spray glue the fleece to the tape and use it to hold down the fleece while I resin it up. once I have 2 layers on top, I pull it and do a layer on the inside.
Trim off the extra material and then add a little filler to smooth out the bumps and she's almost done.
Wrapped it up nice and shes ready to go on the truck
Bad Ass job man you made it look real easy. Is the 8 free air or is there an enclosure behind ???
2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz
19 cubes net 245sq in of port
Sundown 3500 @ .7 Ohm
Sundown 100.4
Rockford Fosgat Power Series
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
1 red top under the hood
2 yellow tops in back
big 3 with 1/0 knukonceptz wire
3 runs of +/- 1/0 knukonceptz wire
IT LBS
trying the door as the airspace on this one. Can seal it up real easy if it doesnt work
Dude, if I shipped my door panels to you, could you make some magic happen?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Whats the cross over points for the 8s???
Sundown 100.4
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
IT LBS
at first i thought you meant an 8" woofer and i was unimpressed
but then i saw a sub. changed my mind real quick
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Nice job billiam.
  • Who's Online   0 Members, 0 Anonymous, 1520 Guests (See full list)
