D2 sa 12's wont play @ 2 ohms WHY?
Are you 100% sure you wired @ a 2 ohm load? if they worked @ .5 they will work @ 2....unless you have a bad coil....pull up woofer wiring diagram @ 12volt.com...and check.....
So if he had a bad coil it would still play at .5 ohm?
Yes, but not @ .5 ohms double check with an ohm meter...he prob got sound wired that way...but @ 2 ohms he would lose going coil to coil..
https://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4Uhttps://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4U
2013 DODGE CHALLENGER R/T
SUNDOWN ZV4-18
CRESCENDO 3.5K
PIONEER AVIC 5300 NEX
ALPINE TYPE R 6.5S & 6X9'S
ROCKFORD FOSGATE 1.5" TWEETS
5 C&D TECH BATTS
x2 on the checking each coils resistance. maybe one coil is bad out of the four. it can happen
And if they share a common chamber in the enclosure one sub moving would cause the other to move giving the illusion that both are getting power.
ohm meter check all coils......thats all..pretty sure he will see that most likely a bad coil...or he can wire each sub seperate @ a 4 ohm load to see which sub has the bad coil...
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
i must be lost as per....
So, if there is a bad coil outta the 4, how would they play at .5 VS 2ohm?... i gotta be reading this wrong.? or the amp not protecting??.. guess i dont understand the " my D2 sa 12's wont play @ 2 ohms" but DO play at .5 question?...
" just bought a new Vibe Blackbox Bass 5 amp that puts out 1500 rms @ 2 ohms i wired my subs to 2 ohms for 1500 rms and they didn't play so i wired them back to .5 ohms and then they played"
Meh,.. par for my course i suppose..
Edit - and regaurdless the issue, nobody reading through this saw nothing weird here?
"So if he had a bad coil it would still play at .5 ohm?"
"Yes, but not @ .5 ohms double check with an ohm meter..."
k, again.. i must be high
i have tried everything and my subs wont play at 2 ohms its like they wont accept signal once wired pos to pos and neg to neg but will accept sinal if wired pos to neg on each sub
when i wire them like this they will not play at all my amp doesnt go into protect or blow any fuses so i know its the subs because i always check the wiring wizards after or during my installs and then i use my mutimeter to test the ohm load
They don't play? Don't make noise ? Have to be wired wrong...
you are wiring them wrong. its pretty obvious. take a picture of how you wire it and post it.
┌∩┐(◕_◕)┌∩┐
I was going to help you until your gangster pic flipped me off.
  • Who's Online   1 Member, 1 Anonymous, 1559 Guests (See full list)
