Amp Clips Immediately, Buzzing Noise from Subs
OrionStang
I dont know if I read wrong or what but did you say they had the speakers hooked up while setting the gain?
I don't even know what they did, the more I think about it, it doesn't really add up. Maybe he spent money he didn't really have. I will hook it up in the morning.
SMD Super Seller
My Feedback Thread
I remember when I tried to DD-1 my 9k with the subs connected I got that same noise and the DD-1 showed distortion with little gain. Not saying thats the problem but from what you stated in the first post thats what it sounds like. If you could ask them if they had the speakers hooked up or not.Worth a shot to eliminate another possible problem
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
Guys, if you have first-run DD-1's you have to watch, there is a diode in them that can pop and cause bad readings.
OrionStang - No subs on output means no load. No load means VERY LITTLE power draw (ohms law). Crank it up as far as you want, it will just amplify the wave form of the input source and give you the resultant output waveform, which is what the DD-1 looks for. The clipping you will find will either be headunit clipping (song/tone or RCA preouts) if it comes near max gain, or amp output stage if it pops up at near minimum to possibly medium gain.
If nothing clips or only near max then everything is likely fine. Could be something as simple as a bad head unit ground in the buyers setup causing "alternator whine" that may or may not have been even audible.
Hammerdown... 1%
I'm surprised Chode hasn't chimed in yet.Seems weird he was there and didn't know to unplug the speaker inputs while testing.Have you talked to him since this happened?
Vehicle
DNX9980HD
3 DC 9k's
8 Nendo PWX 8's
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
21 D1600's
2 D4800's
All SMD RCA's
Viper Alarm
  • Who's Online   1 Member, 0 Anonymous, 1600 Guests (See full list)
