15" kicker comp, box specs.
newb4976
And without knowing what the maximum dimensions YOU have available and the power you are running, we can't do very much...
Also: good luck getting lows with a kicker comp.
i said around 24-33 hz right? thats not extremely low, and i just blew my kicker 10 and it hit 25hz alright.
way too much port area.
67 inches of port is too much? its only like 16 per foot, well i cant do anything different then that, cause im at a stand still, hence this thread, for help
if anyone has plans, or an idea to do around 4 cubes, and 33-36 Hz, without having so much port area, it will save me a lot of brain bleeding.
no...you just said in post 9, its 18sqin per cube. where did you get 16 from?
you're telling me you cant shrink the port width down by quarter inches? 4.25? 4?
i came up with
16.5 x 38 x 20
port 15 x 4.5 x 35
3.76 cubes
34.02 Hz
17.95 inches of port per foot
Will this be ok?
Not sure where you got your numbers from.. But here is what I come up with
i dropped the port from 15 x 4.5 to 15 x 4.25, now it 16.6 inches per foot, instead or 17.95 inches per foot, bu now the box is a little bigger, which is all ok, but the Hz dropped to 32.79
i came up with
16.5 x 38 x 20
port 15 x 4.5 x 35
3.76 cubes
34.02 Hz
Will this be ok?
i got different numbers then you because my port was 15 x 4.5, not 15 x 4
  • Who's Online   0 Members, 0 Anonymous, 3062 Guests (See full list)
