Ok first off. Using the current equipment in my sig, I did a 146.3 at Slamology with the the trunk not sealed off.
I wanted to try sealing to see what happens.. I have done trunk seal mockups before and always lost a significant amount my conclusions from that being that unless the trunk is reeeally sealed off, you will lose SPL. I never did the rear deck in these tests.
So I set out to reaaally seal off the trunk w/o expanding foam however because its so messy.
So I took out the entire rear seating out.
Rear deck got a layer of painters plastic sheet taped down tight and fitted sealed up all edges corners etc
then a layer of cardboard taped down fitted etc etc
The stock dampening went back on top of all of that, it basically covers the entire deck..
The rear shelf went over all that
Taped up any holes underneath as well.
I made a bracket out of 2x4s to go around the trunk opening secured seal and taped it in
Slide the box into the now square opening
Results at this stage: 142.7
I used air conditioning foam around the top of the box from the back even though its very tight already
Added foam paneling around the sides to complete the seal all the way around
Results at this stage: 143.2 [+0.5db]
Ill add pictures later, however my smartphone broke otherwise id have lots of pictures, so i only took a few from my old slider phone.
For all of those people who swear by sealing the trunk WHAT AM I DOING WRONG? Is it perfect? No, but its pretty dang good imo. I spent idk 10 hours easily if not more on this project. And losing 3+ db is a craaazy loss.
Opinions thoughts ideas appreciated,
P4Killer_
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Pictures later, my old phone is being stupid and I have work FML
Edited by P4killer_
Setup:
Xs D3400/ Xs XP3000
Box position
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Tuned in. I am about to do a trunk build and have debated facing the box against the hatch or sealing and facing forward.
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
What org do you meter for and where do you peak. Sealing off firing foward TENDS to favor sealed up metering at a higher peak frequency. If you peak really low, or meter opened up, this doesnt surprise me at all
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
Use deadner over rear deck holes, Put box where you want it, secure it down and then use gorilla tape to seal it off ( like 4 layers snd pit cardboard inbetween layers..
Thats how i got my 150.1 from a trunk
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
3986f0657959__1344625125000.jpeg?tw=0&th=720&s=true&rs=false\
Rear Deck as described above
2854f566af05__1344625393000.jpeg?tw=0&th=720&s=true&rs=false
d47ec9b9cec5__1344625301000.jpeg?tw=0&th=720&s=true&rs=false
Around the trunk opening to slide the box into I Taped it alot more also
21509861e3d7__1344625195000.jpeg?tw=0&th=720&s=true&rs=false
Foam panels and strips all the way around.. almost perfect.
I though I had a picture of the box orientation ill add that in a min..
7d38d9235ad3__1344660328000.jpeg?tw=0&th=720&s=true&rs=false
Edited by P4killer_
Setup:
Xs D3400/ Xs XP3000
