dmm gain setting
ZachG
I say DD-1 cause I only care about the power I receive below %1, I don't care if the amp does rated power at 3% thd(probably a junk amp anyways), I only care for the clean power.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
And other side of the token, just throwing this out there, clipping or at 5% thd, is where you are generally louder on the meter, so for SPL I like to see those points of clipping visually.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
This was a fun read while I ate some popcorn, I must say good points from both sides of the decussion. I just happen to use an o scope to set mine, because you don't know exactly without something telling you it is distorting or clipping. I have used the DMM trick and have blown up 15s doing so, just gonna put that out there, and I have set gains with o scope and blown up 15s, so not everytime is clipping or distortion that causes the failure. Having said that, which method is best, the one that WORKS for you. If the DD1 is quick and simple to use which it is, and that is what you like or want to use go that route, will other things work to set your gains, sure. You the customer is the ultimate deciding factor in what to do at the end of the day.
Set with ear = not sure where clipping distortion is
Set with DMM = not sure where clipping distortion is
Set with oscope = you know where clipping is
Set with DD1 = you know where distortion is
Simple as that. If clipping and distortion matter to you, select the one that applies.
This is pretty much right but iirc
Then if there is clipping there is also distortion.
Meaning to say that the DD1 by finding distortion, makes sure there is no clipping.
There can be distortion but no clipping
There cannot be clipping but no distortion.
Just because the light comes on doesnt mean your clipping, it means your distorting. So in terms of spl where you actually want a tiny bit of clip the DD1 leaves a lil bit on the table..
Im pretty sure thats right lol I prolly didnt word any of that right :P
But the DD1 is stoooopid easy to use. I mean super easy, so its very nice. For the regular guy. If your gonna drop any considerable amount of $ into a system. might as well look into it. itll pay you back over time.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
i don't know, I'm not so sure that theory is always right either. I have seen more people GAIN db using the DD-1 then lose. We never "claim" that you can gain DB but we have seen it over and over again over the last year. Even with LESS overall power.
keep in mind, also, the DD-1 isn't just to "penalize" you and make you turn your gains down......in fact, more people have realized that their gains were TOO LOW (before) and they got to turn them up some (after) using our product.
Follow my Tweet (Twitter)
When I got my dd-1 i had my gain low. It actually made a big difference.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
although the DD-1 does NOT look for clipping, it would still never let a clipped signal pass without lighting up the red light. By the time a signal is clipped off, its already distorted. So even though it doesn't LOOK for clipping, it will still show it.....because its distorted.
Wow. Never thought this discussion would be about trying to compare a dmm to the dd-1. To say you can measure the dame AC line condition with a dmm over a scope based unit is crazy. At least there is some room for discussion between the dd1 and scope. But even a scope isn't designed to set a limit on what percentage you are seeing. So why not use the right tool for the job? Ignorance is bliss
I can see your points and they are very true, BUT....on a 3 sec burp clipped to hell and back is almost always good for a tenth or two on the TL. Seen it too many times for it to be wrong lol.
Evo X build log
never once compared the two. again, all i said was that the dmm method is effective.
dude, you are IMPOSSIBLE. You have No clue on why a gain is on the side of an amp. You keep thinking your way is proper, and i will keep teaching people the RIGHT WAY. The DMM is a joke for setting gains just like using the clip-light.
.... ok... so i ask nicely for a technical explanation and thats your reply? you know... there is such a thing as a friendly argument.
i dont think its a secret, on this forum, that I know a thing or two. i think you yourself know that im not some idiot, as you like to portray me.
as this has clearly turned sour, ill just leave this thread alone, regardless of your next comment.
  • Who's Online   0 Members, 0 Anonymous, 1861 Guests (See full list)
