Dash Mount Amp Dyno
reharrac
me too. i cant wait to see someones response to that
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Interesting piece. Here's the major problem I see, the misapplication of Ohms law. Volts X Amps = Watts ONLY works for DC circuits, or where the load is purely resistive (a non inductive resistor). This is not an opinion, this is fact. An amplifier's output is not DC, so clamping, or doing what this piece does (measuring the voltage and current to the speaker and multiplying) is incorrect and inaccurate and only applies to DC circuits or AC circuits with purely resistive loads. A simplified formula for trying to measure power in an AC circuit would be Volts X Amps X Power Factor (phase angle) = Watts. If you don't know the phase angle, your measurement is pretty meaningless. The Amp Dyno uses precision non inductive resistors to do it's calculations so the power factor is always 1.00, and thus can be eliminated from the equation.
Second problem: What about clipping? How do you know what is actual usable power and what is just clipping? WIthout using an oscilloscope or the DD-1 during this test, it is again meaningless.
Besides these things it's a neat idea. Please though guys, let's quit making up bogus audio terms. "Ohmage", and "Wdc"? There is no such thing as Watts DC, or Watts AC, or Watts RMS, or Watts Peak.... fml. Its just Watts. I'm not even going to get into "ohmage"
Here is a related discussion from a while back. http://www.stevemead...er-by-clamping/
Apparently, we are not the only industry with this problem. Check our the White Paper from APC, the backup power people
http://www.xand.com/...TNQYF_R0_EN.pdf
We will make a video to demo the situation
:bow28:
Follow my Tweet (Twitter)
got quiet QUICK.
1, thats not an amp dyno, its a monitoring system.
2. Its alot more that the 100 buck you wanted someone to build you one for.
sorry, but you dont get a cookie for this one
i wanted to pay someone $100 to find me a designer . i would then pay the designer whatever they wanted
there are a lot of people that use amp clamping for testing. even if it does not tell you the exact amount of watts it will still be a reference point. it will tell you the difference between the amps that are tested.
  • Who's Online   0 Members, 0 Anonymous, 2255 Guests (See full list)
