Yessir -- that is the 10" cone tooling :) It's designed to support a full 50mm one-way excursion.
The 12" is even larger; supporting 55mm and the 15" is biggest supporting 60mm one-way.
Also tooling an adapter for the 18" 6-spoke for a 257mm spider (same as our new 15 basket) and the same size surround as the new 15" for 60mm one-way.
So a full suite of 10/12/15/18 cones and surrounds :)
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
:popcorn: There is nothing to say other than Holy Surround.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
Jeez. I know what I want for Christmas now... :slayer:
Current System:
Clarion CZ702
Stock 5 channel amplifier
Infinity Reference 4022i 4"
GRS 6.5"
Audiopipe 1800.1
2 RE Audio SEX V2's In a 4th order ported though the armrest
2003 130 Amp Toyota Highlander alternator
And I thought my SA-15 already had some crazy excursion..
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Niceeee surround. Can't wait for these babies to come out so I can buy some 10's
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
So the surround, spider, frame, and motor are all able to go 60mm? Or just the surround, and you just want to make sure you have some headroom?
*New vehicle and system coming soon.*
As of now -- none of our motors are linear to 60mm. Of course "not linear" doesn't mean someone can't force it to go that far.
A Z v.3, for example, allows up to 47.5mm before the coil exits the gap on a stock coil and with the pole extension can get into the 50s before totally running out of steam as a coil will still push for a while after leaving the gap. We had one customer actually bottom a Z v.3 18" out -- which takes that full 47.5mm using "only" the 9.25" spider pack (which will now be available on our 12s -- and the 15s even bigger).
So there is a nice cushion in there for the soft parts -- will relieve a TON of force from the triple joint, cone base, surround, and spider landing as it won't be tugging on anything even when pushed past what the motor can do. Also why I am working on a Z v.4 design with additional clearance as well :)
In most "big boy" woofers based on 4 and 12-spoke frames you run into HARD spider or soft part limits well before the motor and coil are done -- which is when you see triple joint failures, spiders pulling off the frame, torn surrounds, etc.
But we do have the option to push for linearity up to these new limits (which we will be doing as time goes on) -- of course we lose our safety cushion but that is what happens at the edge of performance :)
Edited by sundownz
- Jacob Fuller
Damnnn I am going to start saving for a Z v.4!!! And amp, batteries, alternator and wiring...lol right after I just got everything in something better comes and damn gotta have that, and that, and that..
Thanks sundown!
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
2 Sundown E12 Ported 4cubes 35hz
Rockford P400-4
2 Infinity reference 3way 6x9
2 Polk DB 5 1/4
2x layer dynamat all doors
  • Who's Online   0 Members, 0 Anonymous, 2136 Guests (See full list)
