Going active, a few basic questions "if you will"
newls1
To keep this short and sweet, I will be going active using 5 sets of comps. So thats 10 tweets, 10 mid basses. I've never setup an "Active" stage before and am looking for some wiring advice. Please DO NOT RESPOND if you have never setup an active stage please. I will have 3 4ch amps to wire this all up too. Basically where im confused is do I wire every single speaker to its "OWN" channel, or can I wire 2 tweets together (2ohm load) to have more channels available to me. Just need the masters here like Bill, Ray, etc...... to lend a helping hand please. If Everything has to be on its own channel thats fine, i like the sound quality from 4ohm better anyways!
I love my staffie :good:
So anti FACEBOOK it isn't even funny
Why so many component sets ?? Best practice to set up stage and image is to do more with less ...
Are they all for your front stage ?? or will some go in the rears ??
4 sets are for the front, 1 set are for the rear.... Front stage includes the following: A Pillars, kick panels, then 2 sets per door. Rear fill includes just 1 set per door
You dont have to run them all on separate channels nate... as long as your amplifier can handle the resistance and your speakers can handle the power its up to you. but my .02 is that the lower you can keep the impedance the more efficient your are going to be!
couldve just text someone.....
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
too much for front stage ..... I mean loud probably... sounding nice... probably not so much.... Install is more important.... Do you already have all these components sets? Your plan is to just remove the passive crossover from the equation?
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
What kind of vehicle are we talking about here ?? I'm assuming a 4 dr SUV ...
You must be trying to set up a system to match or get close to a big bass system ... correct ???
Just to be loud and soound good, I would suggset staying passive for starters, test and tune, then go active from there ...
If you plan to go Audiophile ... well, the fun begins ...
Not knowing the speakers or amps. I would run each midbass on their own channel for power. And the only run 4 sets of tweeters on that last set of channels series paralleled to whatever ohm load works. Won't be able to do TA but will let you get the most. This is assuming the amps don't double power with two sets of mids on a channel
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
  • Who's Online   0 Members, 0 Anonymous, 1025 Guests (See full list)
