Smoove's 1996 Chevy Ext cab C1500 Blowthrough RF, Fi, DD, SMD Meters 6th. updated pics start page 89
That is a great looking Dane brother! Who is the handler?
Brie and her sister helps during large shows when they have more dogs to show
that's a big mother fucking dog bro.
Last pic is my fav. Dog is saying "Nahhh girl I'm a bad SOB and I know it."
He is a candyass at home. But when the handlers have him, it's like he knows he is showing off.
  • 1 month later...
Smoove make a update or something lol like bolt a seat in take pics then unbolt it and take more pics haha
2007 4.2L Chevy Trailblazer Crossfire Build
6 Crossfire xs v2 15s
3 Crossfire 8ks
4 Crossfire 6.5 Loudspeakers
2 Crossfire ST-1 Super Tweets
1 Pair of Rockford Fosgate T2 5.25 Components
1 Crossfire C5 800.2
1 Crossfire 400.2's
7 XS Power xp3000s
​6 C&D Batteries
3 Singer Alts
6 Runs of 1/0 OFC (Sky High and Welding Wire)
SMD VM-1
SMD OM-1
Pioneer AVH-p4800BS
Build Log
4th Order BL - http://www.stevemeadedesigns.com/board/topic/189896-4th-order-crossfire-trailblazer-buildlog/
Flat Wall BL - http://www.stevemeadedesigns.com/board/topic/198087-2007-42l-chevy-trailblazer-flat-wall-rebuild-build-log-4-crossfire-xsv2-15s-2-crossfire-8ks-xs-power-batts-singer-alts/
Scores
MECA - 159.2 @ 37hz
USACI - 161.2 @ 47hz
IASCA - 157.9 @ 47hz
I got a little work done this weekend. Had no idea what the hell I was doing with Panel Bonding and still don't :)
So here is my fun trial and error adding support to whats left of my back wall under the rear window.
This crap is not cheap
16g 3/4" flat steel and 16g 1"x1/2" square steel
Both pieces were measured and then matched up so the bolt holes could be drilled at the same time. I wanted to make sure nothing was off when they went back together.
The outside piece was color matched to the truck
A dremel was used to grind off the area getting Panel bond applied
inside piece being prefit
All bolted in from the inside. I left the threaded rod long so it could be used to attach a beauty at some point
And now the not so pretty part. I made a little bit of a mess with the panel bond. will grind it off and clean it up later. the other issue was that the metal piece being bonded doesnt lay flat between the bolts. It layed flat until the whole setup was glued and tightened down.
I do not expect to see to much flex anymore from the back window.
Nice Man no more flex. Looking good
3 Crossfire 8ks
1 Crossfire 400.2's
7 XS Power xp3000s
​6 C&D Batteries
3 Singer Alts
SMD VM-1
SMD OM-1
Pioneer AVH-p4800BS
Build Log
Scores
MECA - 159.2 @ 37hz
Killed the flex an built a way to attach a beauty panel/seal it off :)
