Smoove's 1996 Chevy Ext cab C1500 Blowthrough RF, Fi, DD, SMD Meters 6th. updated pics start page 89
Congrats on winning SOTM man!! The work you have done looks amazing.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
So the Mechman 370 is in. No the OLD front fan Alt I had didn't work in the dual bracket. the fan rubbed on the belt.
So here is my fun for the day
Started with a Powermaster GM large case 200a front fan alt
Mounted up the new Mechman and the older style front fan alt in a dual bracket. I got excited too soon. I was told the bracket was built for the ad244 alt, but of course I had to try the new and old style alts together. The belt BECAUSE of the front fan design rubs the belt. Shit was off by like a 1-2mm :(
Since I had issues that were old alt design issues. I removed the Powermaster and only mounted the Mechman 370 and used a Stinger dual ring terminal.
I will be taking it for a bass run tomorrow :) If anyone noticed, yes there are 3 more grounds than from the first to last pic. More techflex also coming soon :)
why not add electric fans or put a spacer on the fan you have to give you more clearance?
edit: real simple fix.. you just have to find the size you need. the electric fan though i would do.. you free up ponies and you gain 200 amps with the 2nd alt.. and the ponies you free up are very noticeable
http://www.ebay.com/itm/Hayden-3965-Fan-Spacer-Kit-/191418688554?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c9171642a&vxp=mtr
you think like I do. The 200a alt was origanally for electrilc fans, RF 500bd and a 400.4. As you have seen the smaller build never happened back in 2002. Still need to buy the electric fans, it is part of the final plan.
Plenum spacer didn't happen yet either :(
hopefully there will be a vid of said bass run
:peepwall:
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
No new vids yet, but...........
Meter in the port
Meter on the windsheild, door open MECA style.
Did not go fullt tilt and I was holding only 11.3v doing a 20-60hz sweep
40hz peak
Thank you rockFord_Expedition for getting the pics
whats with the voltage
Shit batteries. Soon to be replaced. Their not designed to keep up the pull from a system. UPS batteries are not a good idea :(
Also low 650-750rpm idle doesn't help the Alt do it's job.
