Tips on building wall inside vehicle
IndianaBassHead
What's up guys? I'm starting my new build in my blazer and I need a few pointers on building the wall inside the blazer. I have 3 AQ HDC3 18's. I have built boxes but never a wall made inside the vehicle. The box will be taller and wider at the b-pillar than in the back because I have to squeeze in enough room for 3 18's. Where the back seat goes, it stair-steps up so I will have make the bottom of the box to fit that.
Do you guys have any tips on how to ensure the box is strong enough on the edges where I can't screw it together? I want this box to be bullet proof. I am doing 2 layers of mdf all the way around with the front baffle and the back of the box 3 layers thick. I am also using square tubing for bracing. I am also trying to do a slot port on the driver's side.
Thanks for the help!
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
You can screw it together from the inside using pocket screws.
You can also use put a strip along each inside corner to screw both directions.
They can be square or 45 degrees, but either way they also help by adding glue surface area.
'09 Sierra Ext Cab - under construction
(1) RF T2500-1 -running- (4) RF T1 12's
(1) RF T1000-4 -running- (2) RF T1652-S
Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800
Buncha OFC Knu
Buncha Second Skin
Kenwood DDX814 - Alpine Imprint - RF 360.3
Ya I'm planning on gluing the corners the best I can. I like the idea of using 90 degree steel for the edges. Never thought about that. I really don't want to have to deal with fiberglass. Do you guys think it's necessary?
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
If it was me id glass all the seams on the inside. My wall has 2 layers of chop mat in each seam and 3 layers on the inside roof of the wall with 2 gallons of resin and I built the wall outside of the truck.
Used to have a loud truck
Seems like a pretty good idea. It is worth the extra work after all. Thing sounds bulletproof! lol
Google kreg-jig
I had a truck doing 160's useing it
Just saying
is there any difference between that and a regular pocket hole jig?
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
Not really pocket hole and kreg-jig are the same
Also my truck and anouther I worked on also did 160's with out the use of any fiberglass
Did you just use glue and the pocket screws?
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
