NOOBIEST thing you have done with car audio stuff
use a 1/0 gauge wire for a 4 gauge amp
put all the gains in the amp to the max (i thought it would give you more power lol)
and wire 2 4 ohm subs to one and power them to a 1,800 amp and bye bye subs lol rms 400
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
3 years ago, made a 1.5 cube ported box for a 15 with 15 inches of port lenth and like 1 inch opening. Boxes with noooo port area. Not measuring twice my trunk and having to kick in my box. Tweeters off of hu. Selling jl midbasses fo 40 bucks that retailed for 120. Peel and seal -.- 8g power on a amp that needed 4g. Bad grounds.
Come a long way from that :)
Hahah damn cody
She ain't that sexy. I wouldn't even let her blow me. Those 10 pounds of make up would end up all over my crotch.
you dont find dubstep, dubstep finds you
hu: Pioneer MVH - P8300BT
mids: Alpine sps-600 all four corners
highs: Addictive Audio ECST25A,Memphis PR tweeters back
sub: 15 inch crossfire bmf
box: 4 cubes at 38 hz
amp: Rockford Fosgate Power 1000 25 To Life
140.7 on a non sealed trunk car with a five channel so far (old sub audiobahn aw1505q)
Build Log
http://www.stevemead...ima-56k-beware/
Feedback
http://www.stevemead...s-bfd-feedback/
when I was wiring a head unit without a harness just to see/hear it work, I forgot to connect the ground, and I told my cousin to return it because it was not working, it was bought used
I built a small two channel amp and it had a problem (forgot what the issue was) and I hooked the meter up to the components and when I turned it on, I did not realize meter was on resistance instead of voltage, I burned the chip
(not audio related, but electronics related, thought it was the worst one though) working on a final project for school, I had just bought a LiPo 11.1 battery and it had this female T-connector that I needed to replace with female banana connectors, sooo, I did, to get the same length I cut both the wires at the same time LOL small little explosion, I opened it and soldered the broken trace
I was driving, and suddenly nothing more zzzzzzz injection pump failure.
and there was smoke coming out of my trunk. no fuses
I had 2 batteries in the trunk not fused.
Now there was a plus cable in short circuit.
Fortunately I was able to stop at the gas station, where they came wiht a big fire extinguisher
my first install :nea: :nea:
JBL
Hooked up my wiring harness wrong for my deck. It worked fine with my ipod but when I put on the radio, all my gauges would quit working and my warning lights would all light up one by one. I forget which wires I actually swapped, but I was pretty confused at the time...
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
Ran my power wire 4ga > Maxi fuse holder > two runs of 8ga > homemade distributor block > 4ga > amp.
That's the first one I can think of, besides blowing a bunch of accessory fuse by cutting my stock wiring harness off, every wire at once, without disconnecting the battery. Don't remember if car was running or not. There's more in my build log.
Lane AKA HeroKight
'96 Jeep Cherokee Classic 4x4
R.I.P. Molliboo
$200 for new tires, on a jeep!? Is she stealing them or building them with a heat gun and rubber bands?
You hear that????
That's a category 5 shit storm coming
n8: hey you doing today. What's it like being a bitch? you can pm me if you'd like to explain why you arent one. Just like you did for your vs threads.
^^^Rules. Follow them.^^^
traded my DD1515 for 2 memphis sr12's in a memphis ported box :(
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
Installed a head unit with the power still connected to no ill effect.
I did that at night too. There was a bright spark, and when I finally got the hu in it took me a week to find which fuses I blew. If only I had joined this forum before then...
Lane AKA HeroKight
R.I.P. Molliboo
You hear that????
Let a buddy go to the local stereo shop (unable to release the name)... Well they royally fucked up the wiring job almost fried the amp and headunit, AND caught his truck on fire. I wound up redoing the entire wiring job a few days later for him after his subs cut out and headunit literally shut off when we were going down the road.. They left open wires dangling, grounded to a bolt on the sliding part of his seat rail, twisted and taped the harness adapter where wires werent insulated and touching eachother.. Other than that, on one of my first installs I forgot to pull the inline fuse and let some sparks fly... Ooooppssssss!
