n8ball2013 Posted January 11, 2013 Report Posted January 11, 2013 Ive seen boxes cost far north of that 450 figure. think about the guys paying 75 bucks for a design then spending another 100 bucks in materials. now say you want to cover it. another 20 bucks for glue. Cost of your material which would be another 50 buckjs plus and you are at your 250 limit. Now imagine someone needs to build that box for them. I guess their time isnt worth anything because its at your limit. Don't forget to factor in the cost of electricity the wear and tear of your tools etc that a shop owner has to cover and you can see why things easily get to be close to that figure. I know the last time I asked for a price of a box from a shop it was 600 bucks plus I had to provide the design and this was back in 2003 when you had to design on paper with no torres. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Raptorman Posted January 11, 2013 Report Posted January 11, 2013 Double baffle, 3.6 cubes total. Two 12's, was $225 total to be designed by RAM, built by DL Designz, and then shipped from Oregon. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Trey_Dog650 Posted January 11, 2013 Report Posted January 11, 2013 Thanks for taking the words out my mouth n8 lol 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
OrangeJuiced Posted January 11, 2013 Report Posted January 11, 2013 I know a box like mine would definitely be over $450 if a shop had to build it. Custom 4th order design, gallon of finerglass resin, then take it to a body and paint shop for the finishing touches. Probably closer to $1000. Anyways probably close to $250 for a standard ported box. If you do a blowthrough you probably want it water proof so it needs to be resined and then bedliner. If you do a 4th order box, you can cut a smaller hole and have quite a bandpass to play. 2001 GMC Sierra Build. Body dropped and Juiced
ric006 Posted January 11, 2013 Report Posted January 11, 2013 450 450? Are you retarded? Seriously.. Depending on materials and construction of box. I could see it Seriously.... 450 Maybe higher 450? Are you retarded? Seriously.. Depending on materials and construction of box. I could see it Seriously.... no he is not go get an estimate from a decent shop not a hole in the wall If it takes you over 250 at most to build a box for 2 12's you need to go back to the drawing board and re think what your about to get yourself into.. Seriously.. Not trying to hijack the thread, that is all. Ive seen boxes cost far north of that 450 figure. think about the guys paying 75 bucks for a design then spending another 100 bucks in materials. now say you want to cover it. another 20 bucks for glue. Cost of your material which would be another 50 buckjs plus and you are at your 250 limit. Now imagine someone needs to build that box for them. I guess their time isnt worth anything because its at your limit. Don't forget to factor in the cost of electricity the wear and tear of your tools etc that a shop owner has to cover and you can see why things easily get to be close to that figure. I know the last time I asked for a price of a box from a shop it was 600 bucks plus I had to provide the design and this was back in 2003 when you had to design on paper with no torres. Right N8 i remember back in 2000 when i worked in a shop, boxs started at 500 anything that was made custom sealed or port for 2 12s back then and if you need the box to be 1.5 to 2 ichs 1k and up
ehall8702 Posted January 11, 2013 Report Posted January 11, 2013 Always good to learn how to build enclosures. Go to rockfordfosgate.com and use their box calculator. Makes it pretty straight forward once u lookk up your subs and get specs and displacement. Grab a skillsaw ( or table saw if u got access to one ), a Jig saw and a sheet of MDF and get at it!. Im in St.Augustine, u nearby ill hook u up cheap brotha 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
CJ18 Posted January 11, 2013 Report Posted January 11, 2013 For a basic MDF box for 2 12s I charge $150 plus shipping. If you start getting into extras like carpeting, painting, or glassing, then it would obviously be more. That is what I would look for price wise.
Ryan929 Posted January 13, 2013 Author Report Posted January 13, 2013 Im in ocala and I went to a shop te other day just to see if they had any ideas of what i could do, so my amps are mounted on the back wall above my box and they said that moving the amps and making a box that comes up to the bottom of my rear window would add maybe about 1cubic foot which they also said wouldnt make a big enough difference for the price so i guess the only other option really is to do a blow through. Or do you guys think shallow mount subs would make any difference?
Johny B Posted January 13, 2013 Report Posted January 13, 2013 Move the amps under the seats maybe will help with space? 06 Chrysler 300 Pioneer avh-x8500bhs Hertz Hsk 130.4 Alpine mrp-F600 2 Dc level 4 12s Dc 2k Viper 5901 SHCA wiring KnuKonceptz RCA's SecondSkin/Fatmat Big 3-stock alt
Spencer Good Posted January 14, 2013 Report Posted January 14, 2013 Yeah, i'm thinking he meant shop prices. But still.. I build boxes for people all of the time and I tend to try and stay under $100 if it's 1 sheet. Hell.. people think their work is worth a lot more than it really is. If you've already got the glue, and already got the screws.. what's a $26 mdf sheet and a couple hours of your time REALLY worth?? EDIT: whoops.. I meant in reference to the guy who said 450 sorry about that didn't see multiple pages, lol! 2012 TORed Challenger 4 Alpine Type-R 10 1 Brutus 2400.1 20' Knu 1/0 OFC 1 XS Power D1200
