What are you running on stock alternator?
stock 150 amp
d1200 battery
AQ 2200 .5 ohm
big 3 done
volt rarely drops below 14
this i need to see. what volt meter are you using. you should be shredding your reserve and no way that alt keeps up.
Yes. I call bullshit. I have D1200, AND D3100, wired to 1 ohm. I drop to 13.1 once car is warm and driving. Don't need to lie to kick it.
edit: 120A alternator. I highly doubt 30A makes that big of a difference, especially when you don't have nearly the reserve I have.
Double edit: D925, not D1200.
stock 150 amp
d1200 battery
AQ 2200 .5 ohm
big 3 done
he could have a shitty volt meter that is "calibrated" incorrectly or going off the stock gauge lol
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
stock 150 amp
d1200 battery
AQ 2200 .5 ohm
big 3 done
Lol I have a lighter charger volt meter its probably wrong. If anything i'm not lying my meter is
yeah dude thats what I was getting at. thats a whole lot of draw for sucha small reserve
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
stock 150 amp
d1200 battery
AQ 2200 .5 ohm
big 3 done
You might want to invest in a quality in car volt meter. Or at the very least a Digital Multi Meter so you can at least see how bad your voltage really is.
Everything copper 0 guage
2 runs of 0 guage pos to rear
0 guage grounds all over my damn car 14+ wires
2 Everstart marine maxx 124ah for a total of 228ah
Stock 115? Amp acura tl alternator. Voltage drop 14.2 to 13.4-2 for about 1-2 mins then 11.9-8. Really bad. Its basically the same as playing your sounds with the car not running and having the alternator "charge" the quicky drained batteries. After I have switched to Powermax usa 220amp alt,I never drop below 13.4 full tilt. That's with a saz 2500@1 ohm,and 2 four channels runnign in active with 160amp fuse
Umm 124 plus 124 is 248 :)
2003 f150, 2 ab hd 15 on brutus 2400.1, kinetik batt, big 3, knu wire, image dynamics cxs 6.5 with ppi tweets, pioneer 1din and clarion eq.
I am running 500w rms system total now and will be up to 800w+ when i get my SA-8 installed.
Seems like nothing compared to most around here but it's as loud as i like and all i really want with all my sound proofing.
Stock alt on my '07 Ranger is 115 amp i am going to be running a Alpine MRX-M55 with the SA-8.
Right now i have a 3rd gen 12" Type S running 300w@4ohm and a 1 farad stinger cap it shows it dips down to the mid-low 13v range when i push it as hard as i do.
I am expecting it to maybe drop to the high 12v range when the SA-8 is running hard.
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
1994 bmw 325i
160 amp stock alt
comes with big 3 from factory all 0 ga
knu 0 ga power and ground to amp
Red top optima
DD M1C
2 sa-12's
sits at 14.6 - 14.7 at idle
it dips down to 13.7 if I really wang on it
BMW 325i Kenwood KVT-647DVD
re xxx components
re 6.5 FR's
2 RE XXX 12's
2 US amps MD3D's
2 batcap 4k's
  • Who's Online   1 Member, 0 Anonymous, 1644 Guests (See full list)
