Possible Solution for Mustang Dual Alt Setup
Roots style blower adds the extra pully up top, then bracket a new alt off the side. Plus, roots style will change the stock location of the CAI. May need to do a cowl hood also. You do a roots blower, it changes that upper complete and gives you more direct access to the belt.
http://www.roushperformance.com/parts/Mustang-Supercharger-M90-Kit-2010.html
http://www.shopsupercharger.com/p-874-2010-mustang-46l-3v-magnuson-tvs1900-supercharger.aspx
But for that price, you might as well buy a car just for a system. Then again, you'd be blowned as well ;)
Sorry man, only other options I can think of and you can see it clears up a ton of room for another bracket.
10501650_10203332501847103_1859383749711
Blown
Well on the Brite side you did wanna go fast ..... But 5 grand... I just popped a Molly I'm sweating... Whew...!!!!!!!
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
Instead of using the 6 groove pulley on the inner edge of the belt, use a smooth pulley on the outside of the belt. Just like your idler pulleys and tensioner pulley are set up. You could even get a custom pulley machined with some grooves or treads to avoid belt slippage. With it riding on the outer edge if the belt and facing backwards it would rotate in the correct direction for the cooling system to function properly. Doing it that way the only machining required should just be a custom pulley and mounting bracket. I am unsure of how much belt slip you may encounter though.
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
Can't u mount up top to the right and get a custom hood. instead make it look like ur car is supercharged under the hood.
I was thinking about a top mount as well with an extended belt. Deff have to do some custom work to the hood. Not sure if it would look right on a civic tho.
Oddball question, and sounds like a bitch to install, but do you have room under the main alt to install a 2nd alt?
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Here is a quick Google Sketchup file about what I meant. I think it would be a rather easy solution in comparison to others mentioned and it would go along with your original plan.
http://www.mediafire.com/?4vi2hern0r53r5c
Oh, and for the hell of it. a picture:
My Saab 9000 build
Ive been thinking of a way to do mine dual alt as well. I think mine will be pretty easy though. i just need to replace my a/c with an alt. good luck with yours Ken
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
  • Who's Online   1 Member, 0 Anonymous, 1126 Guests (See full list)
