mtxplod Posted March 26, 2013 Report Posted March 26, 2013 I just recently started a build and to my dismay i have some noise. I have recently ran a new wire from the ignition to my head unit and routed the ground to one of my batteries. I still have issues. turn on/off thump alternator whine and when the car is off i have some static. also i can hear my door chime faintly and when i throw on my turn signal heat or headlights more noise is introduced. I am using... pioneer Avic x910bt (used in previous build and did not have to ground RCA outputs) Soundstream RUB 5.400 (also used in last build) Hifonics BRZ 2100.1(and also used in last build , upgrading soon lol) 3 shuriken bt120's ect. ect. I have check every terminal and ground, everything is tight Thanks for your help!
will77530 Posted March 26, 2013 Report Posted March 26, 2013 pics of grounds what is the etc etc is there an eq how are rcas ran? next to power wire ?
Noel989 Posted March 26, 2013 Report Posted March 26, 2013 Try grounding the rcas? Build Log - http://www.stevemead...-cruiser-el-pt/
mtxplod Posted March 26, 2013 Author Report Posted March 26, 2013 I can have pics of grounds later. but there is two grounds where the rear seat belts used to be they are grade 8 torx screws. i took an angle grinder to it and tightened the living crap out of it with a breaker bar. the RCAs are at least a foot apart at the shortest length. I tried running another set of RCAs above the carpet and over my passenger seat and it helped none. ect. would be 2 + runs of zero (only using one at the moment) and dual input terminals. Also i think this is an important factor that i forgot to include, the noise is only present when the RCAs are connected to the head unit and the amplifiers.
mtxplod Posted March 26, 2013 Author Report Posted March 26, 2013 Try grounding the rcas? Havent tried that yet.
RooTxBeeR Posted March 26, 2013 Report Posted March 26, 2013 Problems like this seem to be coming up a lot lately. Ground your RCA then get back to us. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Tarball Posted March 26, 2013 Report Posted March 26, 2013 I have an AVIC and it had stupid whine until i grounded the RCAs. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
n8ball2013 Posted March 26, 2013 Report Posted March 26, 2013 either your pioneer head unit strikes again or you grounded to a non optimal ground by grounding to the seat belt bolts. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
ric006 Posted March 26, 2013 Report Posted March 26, 2013 it would be nice to know if these guys are buying cheap O rcas
Skullz Posted March 26, 2013 Report Posted March 26, 2013 I used to use radio shack cheapo rca patch cords with no problem for years but they have gone to a higher grade that imo suck compared to the older ones they sold. I now prefer ones with the turbine ground than the cheaper tabbed ones than can easily bend and not hold as well, but with the turbine ones they can have a tendency to grip it too well and pull the plug out. If you have rear struts i would sand around one of the nuts and ground on that instead of the seat belt bolt. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
