corona_jeff Posted May 14, 2013 Report Posted May 14, 2013 I predict a 158.0-158.3 on first few burps.........before testing Quote
JasonJones Posted May 14, 2013 Report Posted May 14, 2013 This is hidden away from the build logs. If it were in there I'm sure it would get more views. But none-the-less... HOLY SHITBRICKS! Quote
AA98hoe Posted May 14, 2013 Report Posted May 14, 2013 What do most tahoes peak at anyways?. 37-42 Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
WCA Rusty Posted May 14, 2013 Author Report Posted May 14, 2013 Alright, I will expect it to be a little higher because its walled off but it gives me a place to start 1 Quote DC AUDIO Phone Number 1(855)SPL-DBZZ Built by Competitors, for Competitors.
WCA Rusty Posted May 15, 2013 Author Report Posted May 15, 2013 couple scores coming up 1 Quote DC AUDIO Phone Number 1(855)SPL-DBZZ Built by Competitors, for Competitors.
evermaxx Posted May 15, 2013 Report Posted May 15, 2013 Wooooot Quote Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
AA98hoe Posted May 15, 2013 Report Posted May 15, 2013 Popcorn ......... Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Nasty1 Posted May 15, 2013 Report Posted May 15, 2013 Me to.......... 1 Quote 2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz 19 cubes net 245sq in of port Sundown 3500 @ .7 Ohm Sundown 100.4 Rockford Fosgat Power Series 5.25 Dash 6.5 Kicks 8 Coaxils Doors 250 mechicman alt 1 red top under the hood 2 yellow tops in back big 3 with 1/0 knukonceptz wire 3 runs of +/- 1/0 knukonceptz wire IT LBS
hatch Posted May 15, 2013 Report Posted May 15, 2013 double the madness in one thread FTMFW guys keep the updates coming Quote
