Homemade Super-Neo Woofer: THE CHEVELLE RESTORATION IS DONE, dampener recommendations??
SKILLZZZZ... I'm watching now... Can't wait to see it assembled
2013 Toyota Camry SE
240a MechMan HO Alternator
1/0 Welding Flex Cable Big 3
CT Sounds 4000.1D
Kenwood XR400-4 Mid/High Amp
SoundQubed Q4-120 Mid Amp
Infinity Kappa 6.5 components
Kappa 6x9's for rear deck fill (coming out)
(4) 8" PRV 8MB450's
Set of SoundQubed SuperTweets
(2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure)
(2) SQ HDC3 10's @ 33.5hz (current build, loving them)
Pioneer AVH-X4600BT
100 sq/ft Stinger RoadKill Sound Deadner
120 sq/ft QMat Sound Deadener
(4) Juice Box Black Cherries
Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0
2 Runs of 1/0 Positive front to back
ToolMaker Everywhere
surprised more people dont use PL1000 actually.
Hammerdown... 1%
Yeah it's probably my favorite gap-filling adhesive.
Solid stuff.
Biomedical/Behavioral Science Major, The (Self-Proclaimed) Undisputed-Homemade-Woofer-King
Super-Neodymium-Woofer Build Log: The D4BA-V.2 http://www.stevemeadedesigns.com/board/topic/169236-diy-super-neodymium-woofer-build-log/?p=2475620
Fucking love Alan you goddamned fucking super nerd lol
When Alan uses big words I don't understand
It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out.
Everytime I see a guy driving a mini cooper I cant help but think he loves cock & (2/29/16)-My wife just bitched at me about throwing out things we don't really use. My response of well we don't really use your vagina so should we throw that out was evidently not the right response. I had to leave the room.
I missed Alan.
RIP 5/29/15 - I love you son.
Never really commented on this, but enjoyed seeing the effort and work you put into this. Pretty damn badass. Mass production? Haha!!
Can't wait to see you get her playin man!
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
For the spider pack, I've seen people that spray activator and then very quickly secure it to the landing, but others I've seen put the spiders , mix it into the CA glue, then spray through the spiders, the only issue I see is my spider pack being too thick to let the activator through? But since I know the traits of acrylate chemical reactions I feel like spraying before clamping is a little too risky, the reaction is almost instant, at least compared to spraying and clamping as fast as possible seems like you wouldn't have nearly as secure a fit if you did that? Or is there nothing to worry about?
I missed Alan.
Nothing to worry about.
Activator only speeds up the cure of the glue it touches, the glue not physically sprayed by accelerator will still cure, just not that fast.
Even when you spray accelerator on a bead of glue, its only curing that top layer of the glue, the glue under that of which you just sprayed accelerator on will still be soft and not cured. This is why people are told to wait 24hours for the glue to come to a full cure.
There is no problem what so ever doing it this way, and once cured its fine.
I dont how many woofers I have reconed, and 1 off special woofers I built with parts from various companies.
Personally spraying the spiders outer edges with accelerator and than rushing to get them down on the landing and quickly clamped is bad.
You leave yourself open for more chance to mess up, and not get them clamped fully before glue may start setting up and have the spider not sitting flush/ fully down on the landing.
Then the issue of what I was telling you in the PM last night about accelerator evaporating rather quickly similar to alcohol, there can be a chance of the same happening when you spray the spiders and are installing the coil/spider assembly.
Plus when I insert the coil/spider when its shimmed out for its final resting, I like to wiggle it back and forth a little bit to really spread the glue around a little bit, cant do this if you already got accelerator on the spiders.
I also have a full bottle of Aerosol activator left, and about 16oz of normal liquid activator if you are out, Id need to pick up a smaller bottle to send you some and shipping charges (usps flatrate) if you still need more as well and I can get that on its way to you.
you have a Maserati?
Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird..
He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke.
2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe
subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12
Amp: pioneer gm9061 amp: poineer gm9601
headunit: kenwood kdc 255u mids: SQ pro mids
midbass: polk db 8s highs: stock
mids/highs: shitty off brand
mommas
I missed Alan.
More pics of mommas car?
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
