Homemade Super-Neo Woofer: THE CHEVELLE RESTORATION IS DONE, dampener recommendations??
Looks good man, bracing for earthquake.
Looks really good man. Did you scuff the spiders with sand paper before applying adhesive? Just a curiousity really. I can't believe more people aren't commenting note that they see an assembled subwoofer. I love it dude.
Not the spiders, just the landing ring. I figured they're already that really grippy mesh material so the glue would soak in and hold pretty well.
I bet people think I'm just lying in the title about it being FINISHED so they don't bother looking, but if they checked they would know I really did do the impossible and got off my lazy ass to finish it lol.
Those new Sundown spiders and some others that are saturated with some sort of resin often don't wick up the glue like if you were stacking loose spiders yourself.
That being said, I've never had to rough up a spider itself, though roughing up the landing helps a bit..... or rather if you clean a basket just don't make it too smooth when you grind/sand off the olld spider and you'll have a better time recycling it. I've never had an issue with not roughing up a brand new basket before applying glue.
Also, I know I'm late to the party, but I KNOW this isn't your last sub build so I'll throw a few things out there.
First, I only use CA glue + activator spray, Adhesive Systems rp4000 to be specific (I buy it by the gallon), except for dustcaps for which I use Goop since I have terrible luck getting CA glue to hold a dustcap on. The CA glue + activator cures in seconds. Clamping and waiting is unnecessary, you simply hold with your fingers until it's set.
The other nice thing about CA glue is that with an acetone bath you can often recycle a coil assuming you break a cone or surround.
Next, I always glue the cone to the frame first, then use just a few drops of glue to connect the neck to the former (assuming former and coil are glued in place and shimmed). Once it's tacked into place, pull the shims and confirm it's aligned true before you lay in the glue thick to complete the joint. It's very easy to pull the coil off-center by slightly misaligning the surround and surround to frame is NOT coming off. From here, if your coil is slightly misaligned you can make minor adjustments to correct and then glue it up tight.
Of course, the tighter your coil is in the gap the more you really need to be careful about this.
Anyway, really great projects. You have a lot of balls to try to assemble something with that much neo in it. That could get very dangerous.
Whenever I see a red spider, I naturally assume bad ass woofer.
Interested to see the t/s parameters of this driver.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
I saw the pics, it's still hard to believe that this is finished. I expected to see my father that abandoned me when I was 2 before I expected to see this done. (yes, I have a morbid sense of humor)
Hell ya man
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
Building your own woofer is way over my head, but props for all the work (and research behind it.)
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
