reverse polarity?out of phase?
flood77
Ok on my amps theres a dial labeled phase they are set at 0, should i play with those or just leave them alone,and should i wire them pos to pos and neg to neg or may doing so damage my subs
Easy way to check is to unhook wires from your amps and hook up a 9v battery. The subs should push outward. If they suck inward then they are out of polarity
can use a 12v drill bat too
if its 2 amplifiers one should be set at 180 and one should be at 0.....try tht and see how it sounds?....
Vehicle: 2000 Toyota Corolla Limited S
Head Unit: DEX 99rs pioneer
Speakers
Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide
Tweeters: 2 Mtx dome, 4 APT eminence super tweeters
Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO
Low Mid Range: 2 18 Sound 10 NMB420
Sub: 2 Z-12 V.3 D1 - Sundown Audio
Amplifiers
Sub treble/High Mid: MTX Audio TA5302 Thunder
Tweeters: JL Audio e4300 4-Channel
Mid range: MTX Audio TC3002
Mid range: MTX Audio TA7402 Thunder 7402
Low Mid Range: MTX Audio TA7402 Thunder 7402
Sub: MTX Thunder Elite 4001D
Alternator: 220amp mechman
Batteries: 3 D3100 XS Power
C:\Users\NYRON\Documents\Enclosure for z v.3.png
Speakers
Amplifiers
What do you base this on?
Op, if the subs are all wired correctly and move the same and are not inverted etc, you can try switching the pos and neg and see if there's an audible difference.
It won't hurt anything as long as both amps are done the same way. You can try back and forth and listen for changes, just remember to turn off your system while doing the wiring.
The sound from the woofer will interact differently with the sound from your other speaker when changing polarity/phase. You might notice a difference and you might not.
Still the most important thing is for all the woofers to be in phase and work together. If they do, you don't really have anything to worry about.
%5C%5CUsers%5CNYRON%5CDocuments%5CEnclos
Speakers
Amplifiers
i'll add to that no of orionstang, 12volt_Trini has no idea whas he's talking about, let alone any idea of how to post a picture.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1079 Guests (See full list)
