2003 Kia Sorento Build log (Pair of Team AA 15's in and playing)
Here's the engine block ground, the stock one I couldn't remove by hand because I believe the bolt was machine tightened, but luckily, there's another insert, which required me to get a 12 mm bolt from Lowes
Fuse holder installed using clear mounting tape so I don't ruin the fuse box cover
Wire sleeve from Sky Craft, and a 2/0 open ended tinned lug with a 1/2 hole to fit the 12 mm bolt
Cleaned with WD 40 to remove rust, sanded down, then grinded down
Alternator cable
Positive cable
Installed
Now charging at 14.5
I decided to keep the factory wiring to
- Use the car when I needed to( like driving it up the ramp to get to the engine block ground and alternator)
- Wiring was weird, and all put together, so I left it alone, and the fuse box had grounds coming from it
- If I decide to sell the car in the future, I can pull out the big 3, and still have a functioning vehicle
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
:popcorn2:
2007 Pacifica
Word is you have some new tweets on the way for this ;)
Hopefully I get the mids to complement them :)
2003 Kia Sorento
Team Subsonic Lows
Looking good so far, subscribed! :)
*New vehicle and system coming soon.*
doing everything good so far. tuned in to see how this turns out
WTF? Hybrid parking? Really? What the hell is going on with these smug bastards?! I want gas guzzler parking right up front so i dont have to circle the parking lot 40 times and ruin the enviroment.
Thank you guys for the complements :)
Hopefully I can get more done soon, and save up for these mids to complement the tweeters :)
http://www.madisoundspeakerstore.com/silver-flute-woofers-6-7/silver-flute-w17rc38-04-ohm-6-1/2-wool-cone/
2003 Kia Sorento
Team Subsonic Lows
popcorn2.gif.pagespeed.ce.ZE_0vKi6aV.gif tuned in, great work so far.
2003 F-150 Single Cab
Pioneer 80prs
All KnuKonceptz 0ga Wiring (all soldered using Sky High Lugs)
Sky High Fuse holders
Big 3 with redtop
Karma SS RCAs
Eclipse EA4000 for Mids
Rockford Fosgate Punch Pro 6.5s
Crescendo RTS-1 tweets
Audio Technix AT1200.1d for Sub
Soundqubed HDS312
Box 2.65cubes @ 32Hz 6'' Aero port
Stock 130 Alt (looking at a Singer 270 Alt)
