Sutliff Posted June 21, 2013 Report Posted June 21, 2013 XS D3400 MechMan 170A Alt Big 3 Rockford Fosgate T400-2 Rockford Fosgate 500-1bdCP (Need other specs, ask away ...) Needing to cable the above RF amps, ... Which of the following options would you choose? 1.) Install TWO POS runs of Knu Kolossus Fleks 4awg ... one run for each amp, along with ONE NEG run of Knu Fleks 4awg to a distribution block, then ground each amp from there. or, 2.) Install ONE POS run of Knu Fleks 1/0, to a dist block, then 4awg Knu Fleks to each amp, along with ONE NEG run of Knu Fleks 4awg to a distribution block, then ground each amp from there. If these were your only two options, ... which one would you choose ... TWO of 4awg, or ONE of 1/0?? Zeke '14 2003 Chevy Monte Carlo SS Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/ Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build Pioneer FH-P8000BT Infinity Kappa Perfect 6.1 Fi IB3 (Two 12", 2-ohm SVC) RF T400-2 & T500-1bdCP MechMan S Series 240A XS Power D3400 & D975
CleanSierra Posted June 21, 2013 Report Posted June 21, 2013 Distribution block with 1/0 in and 4 out. Im not the one you want to try to troll. Just a fyi for you.
Broke_Audio_Addict Posted June 21, 2013 Report Posted June 21, 2013 Option 2. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Tarball Posted June 21, 2013 Report Posted June 21, 2013 Option 2 but you want to ground the distro. with 1/0 and then 4ga to the amp grounds. If you don't have an option to ground properly then save up until you can. The best shortcut when doing you electrical is to do it right the first time. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
N9neMillahhh Posted June 22, 2013 Report Posted June 22, 2013 That's the truth. I fucked up my alt by not doing my grounds right... Option 2 but you want to ground the distro. with 1/0 and then 4ga to the amp grounds. If you don't have an option to ground properly then save up until you can. The best shortcut when doing you electrical is to do it right the first time. 02 Lexus IS300 (2JZ FTW) Mids/Highs: JL Audio C5 6.5s all around Mids/Highs Amp: JL Audio HD 600/4 Subs: four SA-8v2s in 3.8cubes @ 32hz Sub Amps: SAZ3k Battery: Huge Interstate Batteries relocated to trunk About 80ft. of 1/0 OFC.... Head Unit: Pioneer 4200NEX
bighossf150 Posted June 22, 2013 Report Posted June 22, 2013 2. Less hassle running 1 run of 1/0 than 2 runs of 4 ga. Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
Karkov Posted June 22, 2013 Report Posted June 22, 2013 Option 2, but make the ground 1/0 as well, not 4 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
