I was just wondering: would your product(s) work well to hush up resonance in a desktop computer? I figure they would, I just don't know if it's recommended or not. If yes however, I might look into it.
Thank you!
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
It would work but are your really experiencing resonance in the tower? Like panels are vibrating? are they touching metal to metal at the connection points? tried using gaskets/rubber seals on the edges?
Thank you!
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
Not like that, just the fact that it's a large empty box with significant airflow through it causes some noise. I think for the small amount you'd need it might be worth at least trying, you know?
My feedback thread
See above post. I've been building PCs for years so no scrub mistakes were made, and I'm using Scythe S-FLEX and Noctua fans. It's in a Corsair 650D which is kinda big, and I was wondering if hitting the inside panels with some SS would make a change. Stuff like the hard drive isn't going to be made any more quiet.
My feedback thread
I don't get any real noise from my 800D case.... but I am using gaskets on every Noctua fan I use... I get some motor whine because some of the fans are horizontal and cause it but I hear air flow only..... and "sometimes' my GPU fan spins up with the typical high pitched noise .... I see no harm except temps "MAY" go up because it'll retain more heat inside the case. Only reason I've not tried it myself. CCF may be a good try first...
Hang on I had an old thread on this I'll find the link for you. Not exactly sure how much of an answer it got but whatever.
Here:
http://www.stevemeadedesigns.com/board/topic/164635-sound-deadened-case/
Edited by Krakin
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
I would spray the inside of the side panels, and if possible the inside of the case with some kind of rubberized coating. Then use some quarter inch thick sound dampening foam in the inside of the panels.
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
Overkill pro would be the better option to use in that application over the deadener as it will remove any unwanted noises bouncing around off of hard surfaces inside the case.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
