95legwagon Posted July 17, 2013 Report Posted July 17, 2013 isnt the alt pcm controlled? (the computer controls it) i think it is but not sure......that could and probably is the issue i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
wccfan12 Posted July 18, 2013 Report Posted July 18, 2013 What are you using to ground the terminals to metal? I ask because I had a similar problem and the ground felt tight when I tried to turn it by hand, but when I replaced the screw with a self tapping screw it fixed it for me. Try using self tapping screws for ground screws if you don't have them in already. Also if you only crimped and didn't solder your terminals on you gotta make sure they're super tight on there otherwise you'll build heat and cause voltage probs similar to this. Hope this helps! THE ANTHRACITE DYC CRUISER -Fully dipped anthracite grey pt cruiser -4 skar vvx 12's (version 1) -Mechman 240 amp alt -Big three in Cadence 1/0 -1 deka intimidator g31 blacktop under the hood -1 C&D 140ah Batt & 1 C&D 55ah batt in the rear -Re audio/soundstream mids and highs -Hifonics Zues 600.4 -DC Audio 3.5k
White Lightning Posted July 18, 2013 Report Posted July 18, 2013 This could work out better if we had some detailed pics of your setup ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
David Posted July 18, 2013 Report Posted July 18, 2013 Do not use self tappers for your ground, that's just a stupid suggestion. Please if your using self tappers as your ground bolt don't give out advice cause your doing it wrong !!
Moreno93 Posted July 18, 2013 Report Posted July 18, 2013 Did you ever think it might be the alternator...
purplesyrup Posted July 18, 2013 Report Posted July 18, 2013 so your running roughly 600 watts RMS, full tilt, with both amps correct? like others, im guessing you either have a weak battery or weak alternator, also, double check your terminals on the battery, if there is corrosion all over the terminals take them off, clean everything, posts and terminals then try it again, i had a battery get corrosion on the terminals once, and it messed up the power output on the battery big time, all i did was clean tem and then it was fine
Karkov Posted July 18, 2013 Report Posted July 18, 2013 600 watts RMS IMO should run off completely stock wiring and have lights not dim, lol. Hell my power converter has more power than that. (different beast, I know) If you don't have that dumb ground sensor I would add as many grounds as you can fit. Body and frame. I have never done a Big 3 without upgrading underhood battery. Doesn't need to be a big buck battery but something deep cycle/AGM would help. You don't need aftermarket alternator unless you add more RMS watts down the line. As stated above make sure grounds are done properly, wire is oversized, connections are proper and tight. then check battery/alternator. BTW these are just my suggestions. I am not an expert. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
DJ_Stubbs Posted July 18, 2013 Report Posted July 18, 2013 Mine was dimming but then i changed the wiring. Was running 4 Ohms on a 2 Ohm sub. on accident. Made my lights dim a lot. Then i changed it to run 2 Ohms. 2007 Dodge Caliber SXT 2.0L Flowmaster Single muffler + Tip 4 SoundQubed 6x9s 3-way PolkAudio PA660.4 2 MB Quart Tweeters 2 4" MB Quart 2-way New 8" coming soon!
jeepgrand99 Posted July 18, 2013 Report Posted July 18, 2013 I just did the big 3 in my jeep my lights used to dim so bad and now they don't dim at all and I'm running stock alt and my battery is shitty so it sounds like you did an almost big 3 going from 10g to 4g. 1999 Jeep Grand Cherokee Coming Soon!!! In the doors 6 6.5 pwx's and 4 ft1's 4 skar vvx 15s walled amps ct sounds 125.4 and a crescendo 3500 singer 270 amp alt 3 xs d3100
