speaker box on backseat in ext cab?
I wouldn't rule out 8" as not doing want you want
4x 8" on 3.5-4k will be loud as
If you don't plane in running big power then cone will win hands down
And 2x 12" will only have 10% more cone area then 4x 8 so it's not that much more, and 12" subs to take 2k daily will be costly
So with that in mind power will determine which will work better
But the sa8 still get down,
I dont see it being anymore of a hazard than a standard box. I dont plan on just sitting it on the seat literally. I plan on making some handles so its actually strapped down and secure. I didnt factor in it being cushioned. Thanks for pointing that out.
unless it is bolted to the floor like everyone else with ext cabs does it, i wouldnt do it. I dont care how well it is "strapped" down.
It can be done, I wouldn't do it personally, as it is very unsafe. BUT! with some heavy ratcheting tie down straps, wrapped all the way around the box and through the folding part and underneath the seat, it should stay in place enough to keep you and your family safe. But it also depends on how heavy the loaded enclosure is also. Don't cheap out on the straps. Heavy duty.
Also if it was just sitting on your back seat, unless its bolted down nothing really would stop someone from stealing the box.. that's just worst case
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
Mines strapped down to the seats. It doesn't move really. Amps and sub and box weigh ~200-250lbs. Empty box is 80-100lbs alone and is a bitch to get in and out cuz it has to be flipped and angled right. I want to bolt it down eventually but well see
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Go for it man my two 12s i take in n out, not too big a deal.although it don't get put in the bed..either house or truck. I wouldn't consider it dangerous. Mine fits nice when the drivers seat is in position.
Subs up port passenger side sounds best in mine
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
2 Sundown E12 Ported 4cubes 35hz
Rockford P400-4
2 Infinity reference 3way 6x9
2 Polk DB 5 1/4
2x layer dynamat all doors
My 2 and only 2 8s are very loud. If you heard it, it would change your mind faster than you can blink an eye.
[sharedmedia=garage:vehicles:2223]
CAFForumSig_zps376518ed.jpg?t=1364077982
SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
I do mid 30 on 2x 8" with 400rms, haven't tested it on 2k as I don't have the elect to support it,
And they get down to mid 20's with a 33hz tune no problem,
Ummm huh?
4 8s done behind the extended cab seats
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 986 Guests (See full list)
