Amart88 Posted August 4, 2013 Report Posted August 4, 2013 Been doing some research on weather or not I should fuse my 2 charge wires from My Alt to the front battery. I have got a mixed bag of answers. The wires are around 20 inches long. What do you think? Thanks. My 2005 s10 blazer build. 4 zcon 18's walled.
Trey_Dog650 Posted August 4, 2013 Report Posted August 4, 2013 I'd fuse any power wire. 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
Amart88 Posted August 4, 2013 Author Report Posted August 4, 2013 I'd fuse any power wire. Ok. Thanks. Just see some people do not, Is there any dis advantage to fusing them? My 2005 s10 blazer build. 4 zcon 18's walled.
TeamHT Posted August 4, 2013 Report Posted August 4, 2013 I never fuse from the alternator to the front battery, of course you could be safe and cover your bases but I see it as completely useless. If there were to be some form of defect, malfunction, or issue with the alternator it would most likely be a voltage issue, which is not protected against with the fuse. Your choice, but I have never fused alt to battery. Tell me...does this smell like chloroform to you?
tacomaguy1 Posted August 4, 2013 Report Posted August 4, 2013 I didn't on my blazer, but on my truck I did Seems like its 50/50 on people that do and don't Team Flex Issues
OrionStang Posted August 4, 2013 Report Posted August 4, 2013 I don't fuse alt to batts. Its your choice, as you can see already, its gonna be 50/50. SMD Super Seller My Feedback Thread
Amart88 Posted August 4, 2013 Author Report Posted August 4, 2013 Yep. See LOL. Same results I get. 50/50. I mean, If the wire got pinched, it is still getting power from both sides so a fuse is not 100% effective? i think. My 2005 s10 blazer build. 4 zcon 18's walled.
SnowDrifter Posted August 4, 2013 Report Posted August 4, 2013 Fuse it. I'm not sure why people don't fuse alt to battery, but you should. If you get in a fender bender or a collision, you don't want something to shift, pinch the wire, then have a car fire ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SnowDrifter Posted August 4, 2013 Report Posted August 4, 2013 I never fuse from the alternator to the front battery, of course you could be safe and cover your bases but I see it as completely useless. If there were to be some form of defect, malfunction, or issue with the alternator it would most likely be a voltage issue, which is not protected against with the fuse. Your choice, but I have never fused alt to battery. True, if you are only speaking about the alt. But the issue is the battery it's connected to. Should it short out, it's the battery that will be causing an overload on the wire ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
DTS909 Posted August 4, 2013 Report Posted August 4, 2013 No fuse. VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
