XS Power
I believe you would need to have a 16v charging system to run 14v batteries.
Like the 12v systems we have stock charge at just over 14v.
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
No, you can't run it on stock electrical components.
You need a different regulator for the alt that will allow it to charge to at least 16.1v. Plus you need to keep in mind that whatever amps, head unit, processor, etc you purchase needs to be 16v stable.
Plus you need to do some homework and calling around to see what the working voltage range on you vehicle's components are. ABS, ECU, Transmission (if electronically controlled), etc
He can charge 16 Volt´s and work with a stepdownmodule for the normal electricity.
"in the abundance of water, the fool is thirsty" Bob Marley
He's not asking how to do it, he's asking if his cars electronics will handle the higher voltage.
Some do and some don't
Just gotta wait and see if someone that has tried it will chime in or test it yourself
Team Flex Issues
Not sure on fords but my Tahoe runs 14v batts I drive daily at 16.4 .. My buddy just tried his astro on 16v batts an it worked lol
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
If your using the race 14v you better double up. They contain about 20lbs less lead the the d1400 version that's designed for car audio.
He is looking at buying the same ones I got from Ed for $130 each. Hell of a deal.
  • Who's Online   0 Members, 0 Anonymous, 1487 Guests (See full list)
