8th order design challenge
KiKaZz74
Any of the iso boxes look badass I think. Dont gain anything with them really tho.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
:stfu::NeedPics:
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
The "order" of a box actually refers to the rolloff. It has nothing to do with the alignment really. Like a 4th order crossover rolls off at 24db per octave, a "4th order bandpass" rolls off at 12db per octave below tuning AND above (hence the 4th order designation). Just as an aside... a regular ol' ported box is actually a 4th order.
A 4th is more accurately a "single reflex bandpass".
The box pictured is just a aperiodic bi-chamber. It's not really an "8th order". And ABC's aren't any bigger than a standard vented. They're just parallel tuned in octaves.
And 8th would be like a "6th order" inside of a 4th order. And yes... it would be hyooooooj.
Can anyone tell me....What does the "8th" in 8th order mean? What does the "order" in 8th order mean?
Taylor beat me so if his is better (most likely is) use his.
A fourth order has a sealed back chamber with a vented front.
A sixth order has rear vented and front vented chambers.
An eighth order has three chambers. All three are vented. With the front and rear chambers of the sixth order vented into another chamber.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
some good info developing here. in for more.
If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved.
Yes, I do know that a 4th order is a ported box. I didn't realize it was because of the rolloff slope. I don't think people understand that, then. Why would anyone want a subwoofer with an 8th order rolloff slope? Just for SPL competition? if you had no subsonic filter, maybe that would be handy. But any amp today has a subsonic filter. My personal choice is to extend low frequencies as far below tuning as possible without over excursion or unloading of sub.
An "8th order" would have a retardedly small bandwidth but have enormous gain/efficiency. If you could do it right, it'd be an SPL monster.
Incidentally... if you also add a crossover to your 4th order (or whatever) you add an order. Add a 2nd order crossover to your ported box and voila'... you now have a 6th order and you're cool.
An 8th order's rolloff would be 24db above and below tuning. Not 48db either way.. LIke... a 6th is 24db per octave below tuning but only 12db above tuning.
I been looking at the Bose Acoustimass design and from what I can see this is the outcome.
with Qts=.42, Vas=.46 ft^3, Fs=56
you should get
V1= .68 ft^3 Fb1=78.85 Hz
V2= .35 ft^3 Fb2=39.77 Hz
V3= 2.98 ft^3 Fb3=Fs=56 Hz
F3Lower= 36 Hz
F3Upper= 87 Hz
bandwidth= 51 Hz
you should get
F3Lower= 36 Hz
F3Upper= 87 Hz
bandwidth= 51 Hz
That's all well and good... but can you extrapolate the calculations?
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
