2 x DD 9510's not really happy
greggtr
3.4 cubes with a 6" port tune to 34hz.
I loved it .. Was doing 144s on dash with music .only a Saz 3k.
It's ur box
It's the vehicle. The tune could be a problem as well. I'd drop the power and give them 4.5-5 cubes with plenty of port to operate efficiently. Flared ports, on both ends.
5 cubes for 2 10s ???...
i still stand on the 3.4 cubes with 6" aero. tune to 34hz
got nasty low
Rolling with David here.
No way DD recommends a 46hz tune.
More volume, and knock 10hz off the tuning.
The , let it eat.
Great gear by the way.
x2
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Guys its the car
The trunk of these cars is completely separated from the rest of the car. No holes or anything. I am sure it is loud as fuck in the trunk though.
Maybe bore some holes into the trunk area behind the seats to allow the pressure to enter
other than that you are pretty much fucked
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Dd recs a 42 or 40 tune for one. Open air is death the boot that separates the trunk from the top well is death. Expecting too much out ooof an install ij a subpar car
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
he says it is ported into the cabin but I am seriously wondering how. Stock these cars do not come with any kind of pass through
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Hi Guys,
I finally finished and tuned my car...
Car 2003 Miata
Head Parrot Asteroid Smart 3v pre-out
Doors 2 x DD AT28
4 x DDAW3
2 x DD W6.5
Amp DD S4b
Boot 2 x DD 9510
Amp DD M4
I LOVE the front stage, was extremely surprised how clean, clear and wholesome the front stage is....
The Subs are a let down, they are in a 2.5 cubic foot box, facing the back of the
car, 2 x 4" ports 8"long , tuned to 46-47hz directly ported into the cabin.
With the boot open I hit 136.2db at the dash, with the boot closed 133.4db
My issue is, I feel I should be getting MUCH higher db, I am pumping around 5000w of power into
2 SPL subs in an less than optimum (but still acceptable) enclosure.
before you reply.... I know convertibles are bad at db, but I like and car, so don't say "change the car"
Please advise....
this is your problem.
No and there id a well the top fold down into that would cause you to end up with a wet trunk if you cut into it. Unless a ton of worm has been done and the car is no longer a vert. He could get a hsrd top for it and kill the whole vert assembly.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I have done many miatas,there are three things that greatly reduces SPL in that vehicle,the trunk floor is very thin,you cant see it but it is flexing like a mother fucker,your steel trunk,needs more mass and some deadening,because the trunk is held on by two tiny arms that are riveted & weak,the metal frame above the gas tank,below the rear window will also flex and cause a horrible metal vibration noise.
I did a single sundown 12" and a saz2500,and it flexed the shot out of everything even after fiberglass & deadener (alot!)
I have found this trunk loves 36hz tuning. Depending on box position &subwoofers
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
