Why do I keep killing battery's?!
Okay.. First off I have a 2003 jeep Grand Cherokee
Stock Alt
Big 3
Knu CCA although
AQ2200.1
Now, I had 2 1400 Kinetic battery's.. One as a starter and one in the back.
The one in the back after a month stopped holding a charge and would only hold a charge to about 11.5v.. So I put my old starting battery in and out the 1400 starting battary in the back.. Now the back battery is only holding a charge to 12.1
Why does this happen? Ground Issue? Not enough power?
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Nit enough alt you cany expect to abuse batteries and not top them off frequently
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
nuff said
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Charge them before trying to look at anything else. Every other day ;)
I throw a 1amp on it least once a week over night
Team Subsonic Lows
Have you also checked your power cable running from under the hood to the back? Maybe you melted the fuseholder or something and the back one isn't really being charged...not that that's happened to me or anybody else recently...peepwall.gif.pagespeed.ce.8qvPVxl3av.gif
A8482433-7A78-48E6-A0A9-AB2B945AC8AF-638
But seriously, check your connections and make sure nothing's loose/arcing
Checked wiring.. And I know it's only a 1amp but people said itd be fine.. I have multiple friends that have extra battery's & never have to charge them.
Team Subsonic Lows
Do they have stock alts and stupid draw dont you run at .5
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 724 Guests (See full list)
