Sky High Car Audio
How would you go about preventing corrosion on theses things? I am going to have one on my alt output stud, one on the alt case, and a few attached to the frame for grounding.
Just some grease? Flex seal?
Looking for some suggestions/ideas here
as long as its pure copper it should not corrosion I got copper terminals for 4yrs still looks brand new
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
^^X2 tinned copper ftw. You can put some sort of silicone grease on it. Should help with keeping out moisture
I seem to recall Jon talking about tinned lugs some time ago
I got pure copper an its been 4yrs or so they still look new
2 sundown sd-2 d4
flex tech
box design by Joe X
I would recommend the Tinned Copper lugs. I got the tinned copper 1/0 lugs from a solar company for about $1 a lug. And then I soldered everything for that much better of a connection and to keep the wire from oxidizing and the copper from corroding.
Link to said solar company?
  • Who's Online   0 Members, 0 Anonymous, 3333 Guests (See full list)
