Squeezing more voltage from your alternator.
Either using XS pluging modules, external regulator with analog adjustment or "other tricks" to get the most out of your alternator. Tweak it at the source!
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
mix mdf sawdust with wood glue to make your own mdf putty.
or if you have a little gap / crack then apply glue directly into the gap and lightly sand the surface around it and on top of it, the saw dust will work its way into the gap and stick to the glue creating a natural filler. when the glue dries the filled area should be hard as a rock.
Better yet, Resin and mdf dust!
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
lay a ring of rope caulk around the perimeter of where you mount your sub in your enclosure to get rid of air leakes. it also looks better than other methods i have seen.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
Ive seen the rope trick done for boxes as well
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
if you need to run a thin wire through firewall or dash then straighten a metal hanger, then tape the wire to the hanger and run it through that way.
Big ass zip tie to run RCA/speaker wire.
I use a car antenna that I cut the ball and connecting ends off and sharpened one end. Just gotta be careful, but it is great for pulling wires up through a dash and out through a grommet for you tach, hood pin, etc. For larger gauge I have a wire grommet tool..
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
Bolt terminals made for $5. Best thingf ever. With wing nuts, for easy modifications.
  • Who's Online   0 Members, 0 Anonymous, 772 Guests (See full list)
