6 rockford fosgate p3 10s in wall help wanted box!!
codyh515
I have a 1990 Buick century and I need help with box dimensions and port tuning I know how to build myself I jusymt want a crazy loud system I have 6 10 p3s and will have 2 t1500 running a set of 3 on each amp. Please help me!! Tuning possible in the 30s that would be as low as I wanna go no higher than 40 . Anyone please help..
34in height, 50in wide, 20in deep,
Well no one knows your max dimension. Theyd need thst to design you a box
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Measure it all out and post them up
Are you going to build in car or outside and fit as that makes a big diff to what will fit through the hole you have to squeeze it though
If need be make a cardboard box first to see what you can get in,
I take it you have d2 running at 1.33ohm
And as your not strapped
Idd recommend splitting the box to 3 per box as gain matching is not a easy feet
Nahh I have the p3 d4 but I guess I'm going to build the box outside the car and to fill in the space I'll just make some beauty pieces. But the dimensions are 34in height, 50in width, 20in depth. And I'm going to run a 3sixty.3 on all my equipment. So it can be fine tuned. So the tuning on the amps won't be so bad so I can run peace set of 3 in one box. Or do you think I should still run two separate boxes as a wall?
