is there really any noticeable difference?
I'm happy people still believe in the more expensive RCA's sound better, that'll keep the cable companies happy. :suicide-santa:
Even on thousands of dollars of audiophile equipment in a home (which is a better environment for listening to quality music) you won't hear a difference.
Obviously there is a placebo effect to a lot of people.
Every RCA's will work properly as long as it isn't a dollar RCA's, the cables/connections can be pretty brittle.
By the way, I use a lot of (expensive/quality) RCA's but that has nothing to do with performance, but more so for looks and feel.
i also want to add to my post that i did not really hear a difference. but the quality was much much better as far as a installation point of view! would i buy a cheap pair now? no! would i spend another $50+ on them again if and when they break down yes! they just hold up so much better and there really nice to look at
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
install, install, install. i use cheap $2 RCAs all the time and never have an issue with them.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
thanks for that video, never seen It until know, I knew there was a difference but didn't know how to figure out what amp had what.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I watched that vid this morning when searching youtube. I have sent a return order to sonic for the twisted set I had ordered and bought the copper shield SE cable.
I took my dmm out to my car and tested the amp and found that its ground on the outer and the signal is center like the top diagram in the vid.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
can't wait to test my new amp and see what one i need! someone needs to make a list!
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
