The Automotive Picture Post
That's gonna hurt the wallet.
Both walked away too
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
No idea bt is love to see the trailer queen
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
FML
25356958856_3690a54e18_b.jpgLSMotor by Kenneth Stephens, on Flickr
this is the reason i went with a junk yard ls3.. its more expensive than the other lq engines but im saving lots of money by not going crate or ls7.. i was reading on my block and it looks like i can build it into a 418.. that would put me $2000 for the crank and pistons buy a used set of ls7 heads and i will still be under at 6k around 9k installed and everything
can you bore a ls3 block to 4.125?
i think the ls7 heads need a minimum of 4.100 bore
FML
You can't use LS7 heads on a non LS7 or aftermarket block. Not only does it use a different bolt patterm, but the bore on an LS7 is 4.125", and it would ruin the quench area of your pistons as well increase pinging and drastically lower your compression. The L92 heads on the LS3 are KILLERS, i'd personally rather have them CNC'd than throw on oddball LS7 heads.
i dont know where you get your information from
texas speed have done it but its pushing it
We have done it before if someone absolutely wants it but we don't recommend it. That's how guys are getting away with running LS7 heads on a LS3 block. You can build an LS3 422c.i. motor going with a 4.100 bore and a 4.00 stroke crank. If any way possible, 4.080" is about as far as we like to go.
Shitty thing is the Mustang is totaled and the owner can't afford to fix it, while the Vette is fixable, and that "team" already has a twin of the vette.
Like they say, "if you can't replace it don't race it"
