fullburn420 Posted January 16, 2014 Report Posted January 16, 2014 So I live in good ol South Dakota where it gets nice and cold in the winter. While its not too terribly cold here now (30 degrees) i want to know if i am damaging my woofer by playing it. I dont just hop in and go full tilt. Usually i let my car warm up then jump in and give it about half volume for 15-20 mins then i turn it up to 3/4 volume for about the same time after that i go full tilt. I was wondering if this is bad for my woofer or should i just pull it for the winter...even though its kinda late in the winter for that lol. 2000 Ford Explorer Mid/Highs Pioneer Headunit Pioneer fh-x700bt Amp Earthquake Mini D2500 Sub Rockford T2D415 0/1 Wiring 5%Tint All Around
DubNDodge Posted January 16, 2014 Report Posted January 16, 2014 To each is their own. Some go ham right after they let the car warm up, some go ham as soon as the car turns over. I don't go full tilt in the winter. Just for the fact that I don't want any thing to become broken. Everything is more brittle in the winter at colder temps, so interpret that as you want. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
fullburn420 Posted January 16, 2014 Author Report Posted January 16, 2014 thanks for your informative post ill keep that in mind 2000 Ford Explorer Mid/Highs Pioneer Headunit Pioneer fh-x700bt Amp Earthquake Mini D2500 Sub Rockford T2D415 0/1 Wiring 5%Tint All Around
ChevyBoy95 Posted January 16, 2014 Report Posted January 16, 2014 you should be fine at 30 degrees, but like 20 on down i would personally ease into it. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
SnowDrifter Posted January 16, 2014 Report Posted January 16, 2014 I've tapped the my triple joint against the top plate when its 17 degrees out. Haven't had a glue joint/spider/surround failure yet. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Dangrebel Posted January 16, 2014 Report Posted January 16, 2014 I've been playin full tilt in 20 degree weather no problem lol. I hope 1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps,
Tarball Posted January 16, 2014 Report Posted January 16, 2014 No woofer issues but fully tilt with the windows up and mid 20s was when i cracked my windshield. As mentioned earlier - everything is more brittle as the temp goes down. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Novak Posted January 16, 2014 Report Posted January 16, 2014 I heard some spiders are extremely brittle in winter. but I never looked in to what manufacturers they were talking about...... but on a side note electronics perform a small percentage better in low temps.... so ur amp is good 98 honda civic hx build in process have need sundown x-12 d4 more sound deadening sundown saz1500d v2 alternator (mechman) sky high 1/0 w/ big 3 false walls and fiberglassing amp rack (half done) and box processor kicker zx 200.4 (mids/highs) infinity reference components trunk lid rear deck and rear quarter panels deadened kinetic hc1400 under the hood (picking up 2 more late Jan early feb) check it out http://www.youtube.com/watch?v=1wF0CV2NaX4 November 9th, 2013 metered 140.3 at Midwest audio &detailing sealed on dash w/ termlab (w/ old alpine amp, new amp yet to be metered)
fullburn420 Posted January 16, 2014 Author Report Posted January 16, 2014 not too worried about the amp mostly the subwoofer. Hopefully RF spiders arent too brittle 2000 Ford Explorer Mid/Highs Pioneer Headunit Pioneer fh-x700bt Amp Earthquake Mini D2500 Sub Rockford T2D415 0/1 Wiring 5%Tint All Around
leonfowler Posted January 16, 2014 Report Posted January 16, 2014 you can burn your tinsel leads up if you play high notes in cold weather for a long period of time 2004 Chevy Trailblazer LT Walled- 10.5 cubes net tuned 33Hz 2-15 inch AA Team subs D2 Americanbass- 750.1 1 yellowtop under the hood , 4 c&d 88ah batteries in rear mechman-270 pioneer headunit-4200UB 4 soundqubed supertweeters phoenix gold 2 channel back up camera stinger volt meter 22 years old and still have alot to learn..lets get it
