Lower tuning?
Beanz
So I just built a box and it's not hitting the lows lime I want to. I made it to where it's a center port and I was wondering if I can add pieces of wood at the end and just clamp them down with clamps to temporarily hold them down and see if they do anything. Would it be possible or am I just crazy?
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
If you do that your internal airspace is going to plummet. Leaving your box on the small side
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i've seen external ports in order to extend the port/lower tuning. L brackets and such.
i would just rebuild the box rather then try to "make it work"
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
I would try adding an external extension to the port first to see if that helps. If so then completely rebuild the box to proper specs
Edit: What are the box specs and woofers used?
TDH FTW !!!
It would be best to say what subs and post the design.
could extend the port externally for a lower tuning.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Extending the port and leaving the same net ft3 will increase port area per foot and a few other factors. Yes it may play lower but at the same time you might have a peakier box. What you could do is maybe shorten the port on the inside and extend it from the outiside.
  • Who's Online   1 Member, 0 Anonymous, 1761 Guests (See full list)
