What to do when t-nuts fall out!?!?
JeepAndBassXJ
So I redid all of them and glued them in with CA glue, and instead of using philips head bolts I switched to alien bolts with nylon washers. I think that will work better and I shouldn't need to be taking the subs out again, but I have said that before lol.
YouTube: https://www.youtube.com/user/JeepAndBass
Website: https://www.jeepandbass.com/
My Jeep: 157.3dB @26hz Drag Style 162.3dB @36Hz Outlaw 160.7db @35hz Headrest
My Honda: 155.4dB Drag Style 158.0db Outlaw
That would be awesome but I just realized that I have ~1/4" holes from the t-nuts in the box so no screws will thread into that. :(
Rotate the sub a few degrees and drill new holes?
If you're not ocd lol
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Have you thought of going the threaded insert route? I have found that those seem to work soo much better than T nuts because instead of mounting on the inside of the box they mount to the face of the box, and still give you the threaded option.
Firm believer in letting my cars do my talking!
You can't rush quality, it doesn't happen overnight. Quality takes time and dedication, but the end results more than pay for it.
"Black Pearl" Build Thread
http://www.stevemeadedesigns.com/board/topic/67183-1985-buick-regal-limited-build-log/page-1
Mine are glued in. Why are you putting so much screwing force in the bolt? This
will push the nut out when it should be all the way seated in the wood... If you
are using 1\4" bolts then the actual hole should be slight larger for the
whole nut to fit inside... Screws snapped on me in the pass thats why
i use t-nuts..
X
MY BUILD LOG>>>> NAH I BETTER NOT..
  • Who's Online   0 Members, 0 Anonymous, 3301 Guests (See full list)
