Knu 1/0 370a alternator ok with one run?
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
I have a mechman 370A elite and was told by mechman that you should only have one run from the alternator as multiple connections can cause resistance and overheating of the alternator.
My question is, would a 16 inch run of Knu 1.0 be sufficent on the 370a to the front battery? just curious before I change anything.
I know the wire is rated for 300a.
whaaa? more wire and more copper terminals = more resistance???? that's a new one.
You DO NOT want to stack terminals on the alternator. Stacking ring terminals on the alternator WILL cause the regulator to overheat..
I was just told over the phone, to use two on Power and two on ground for a 270a ? Im confussed now...
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Could you explain why for us? Not busting your chops or anything, I was actually thinking about it for this summer when I upgrade my wires and I'm curious now.
The regulator will overheat and possibly burn up the regulator. If you need multiple runs run them from the battery.. NOT OFF OF THE ALTERNATOR
But why does it heat up? Not trying to be an asshole just genuinely curious.
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
I have 2 on my post.. No issues yet. I'd like to hear an explanation because I don't see how that is a bad thing if connections are tight
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
The regulator will overheat and cause the alternator to be less efficient
But why does it overheat?
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
Team DC Audio
  • Who's Online   1 Member, 0 Anonymous, 1689 Guests (See full list)
