Bass is nice and loud then soft
juan777
Pioneer 4600BT
Dual alt setup with 370XP DC Power for bass amp exclusively
2 Group 31 Crescendo Batteries
Soundqubed Q3500.1
2 HDC418s in Joe X designed box
Amp was set up using DD1
All,
My system has been acting weird lately, (Past 3 months or so). For about 30min, my bass will play nice and loud. After the 30min or so, bass will get cut in half, just bass, not mids or highs. I thought it was the grounds so I checked them, both amp outputs are grounded to the batteries and the batteries are grounded to the chassis, yes the paint was stripped off. The amp is connected directly to a new pioneer unit which I bought about a month ago thinking it was the old head unit, also a Pioneer which was old anyways and needed replacement.
No other issues, weird smells, or noise. Nothing else other than what I just described.
Please help!
Juan777
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
I would start by checking conections, pull the subs check those as well.
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Connections are solid I double checked them, if it was the sub connections then wouldn't 1 or both subs stop playing instead of just playing softer?
RCAs maybe? I'll swap them out and test.
What about a faulty bass knob?
The L@zy Hoe
2005 Chevy Tahoe
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
24K Watts
4 Custom 18s
The Build Log
if speaker wires are loose, one of the voicecoils could get disconnected temporarily which will definitely cause the bass to be quieter.
edit: those AQ/SQ bass knobs aren't the greatest. i went through two and the second one was even starting to go bad. use a PAC LC-1, its reliable and works great.
RCAs swapped out still same thing, I'm gonna take the bass knob out of the equation since all I want it for is the clipping indicator. I will also re-set the gains with my DD1 again just because.
Rechecked grounds for resistance, they are solid grounds.
I will reply with findings
Thanks for all your help everyone
The L@zy Hoe
2005 Chevy Tahoe
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
24K Watts
4 Custom 18s
The Build Log
I like your equipment choices. Pics.?
Tuned in for conclusion of your findings.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Def take the bass knob outta the equation man. I used to have a bass knob on all the amps I owned and they all went bad at some point as in the wires would start to get loose on the back and it definitely affected the loudness of my setup. i don't run bass knobs anymore cause it's too much to play around with. My car already feels like a spaceship when I do all the necessary things to turn the system up lol. I would get a pac LC-1 like others suggested if you really want a bass knob I've never heard of anybody complaining about them I might get one here in the near future myself. Hope you get that problem fixed though man you have some solid equipment for sure!
THE ANTHRACITE DYC CRUISER
-Fully dipped anthracite grey pt cruiser
-4 skar vvx 12's (version 1)
-Mechman 240 amp alt -Big three in Cadence 1/0
-1 deka intimidator g31 blacktop under the hood
-1 C&D 140ah Batt & 1 C&D 55ah batt in the rear
-Re audio/soundstream mids and highs
-Hifonics Zues 600.4
-DC Audio 3.5k
Only read OP
Verify RCAs on back of head unit, any bass knob you have, and on the amp are tight.
Pull your subs and check the wiring is intact and that the tinsels aren't loose or have any breaks/fatigue spots in them
  • Who's Online   0 Members, 0 Anonymous, 769 Guests (See full list)
