Wouldn't the gains be lower if the gains were set with the car off? To me it sounds like you should set your gains and at what ever voltage you set them is where the amps would clip at. So if you set it with 14.4v then anything below that your clipping?
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
I remember asking this a long time ago when I first got mine, and everyone said engine on. I'll keep doing it the way I am doing it lol.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Ive always set mine with my car running, never had a problem what so ever. When Steve is showing his videos on YT doesn't he always have the batteries charging at the same time? that would almost be like having your car running wouldn't it?
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
Do as I say, not as I do.
Then no one would run <1ohm, make 4th/6th orders, and other things like that. lol.
On topic here, want to here some from more educated people(Mr.D'Amore himself???)
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Let's get tony in here... I already pm'd him on facebook
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
The manual does not say, ...which is why I said it does not matter.
Dicking around last summer, I adjusted my two RF Power amps, & I cannot even
begin to explain how tiny a difference there was between the same tracks & same
H/U volume levels, etc.
If I had to put a number to what the differences were ... it was less than HALF of one number. If it was a 3 OFF, then it started tickling the distortion LED just shy of 3.5.
I will just end this with stating that this was MY experience with the DD-1 that I had, & the system & set-up(s) I had. Your experiences may differ.
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
It was said long ago from Steve himself, I believe, to set with the vehicle OFF. The reason behind it was so the noise of the vehicle itself(alternator whine for example) wasn't a possible factor with the vehicle being off. With the vehicle OFF, there isn't going to be that possible distortion to allow the device to accurately measure and isolate what's going on with the amp and HU.
I've always done it off and even let the bats go down turning my lights on.
From Tony before I even had my amps in. Facebook message.
"I'd use car off because the voltages will sag when the amp hits, so it will be closer I feel "
I run normally in the low 13's. Lol. Soooo. That's just me.
  • Who's Online   1 Member, 0 Anonymous, 1284 Guests (See full list)
