crispy_chick3n Posted April 27, 2014 Report Posted April 27, 2014 Hell with mfi, carb it! I can get 4150 manifolds for that engine. only issue with a carb on it would be getting the CEL off, and getting things reading correctly for emissions. with the mfi system there is support from chevrolet so people who need to can still pass emissions. yes you would be able to pass emissions with a carb, but it would require more work to be done This page is crispy_chick3n approved. © crispy_chick3n inc
sphinxbccp Posted April 27, 2014 Report Posted April 27, 2014 My blazer had most of the same problems, a can of MAF sensor cleaner and about half an hour of cleaning it and i was good, all codes cleared themselves and to this day i haven't had another code. It didn't look dirty either, but a 10 dollar can of cleaner its better then replacing all my O2 sensors like the "professional" was telling me Build log: Click Feedback: http://www.stevemead...xbccp-feedback/ 03 Chevy Blazer - IPad Air 2 - ALPINE Head Unit - 4 DC XL 18s - 2 DC 3.5k - ALPINE TYPE R 5.25 COMP - 3 ALPINE TYPE R 6.5 COMPs - DC 175.4 - DC HO Alt - D3400 - 4 XP3000s - KNU 0ga - 60 SqFt Damp Pro Lots more...
Tarball Posted April 27, 2014 Report Posted April 27, 2014 Just seeing this thread for the first time. I assume you are have the CSEFI engine and not the MFI. As mentioned the CSEFI uses the spider injectors. What plugs did you use on the tune up - I recommend only AC Delco platinum on the vortec engines If you sprayed any type of cleaner into the intake while the vehicle was running - TB / Carb / MAF / EGR cleaners - then chances are your CAT is clogged and needs to be replaced - with 80x thousand miles on the Cat its a good bet its bad anyways on a vortec. Find a place that sells gas without ethanol and don't go anywhere else for gas. You probably need to replace all your 02 sensors and the Cat and maybe even the muffler - I have had the cat go bad in these and shit itself into the muffler - cat was empty when removed and all the guts were clogging the muffler. Have you done a compression check yet? CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
ParDeus Posted April 27, 2014 Report Posted April 27, 2014 Emmisions? What tree huggin, Obama humpin, tofu fuckin state does he live in? On the real, I always forget about emissions. I've never had them where I've lived.
boom50cal Posted April 28, 2014 Report Posted April 28, 2014 Emmisions? What tree huggin, Obama humpin, tofu fuckin state does he live in? On the real, I always forget about emissions. I've never had them where I've lived. Utah, Fuck emissions. OKLAHOMA! Correct me if I'm wrong but wouldn't he have to run a standalone tranny controller too? Or could he use the factory PCM? Off topic.. Clogged cats, fucked up pressure regulator, and failing spider injectors. http://www.fuelinjector.citymaker.com/Vortec_spider_fuel_injection_conversion.html Wild shot in the dark, but it could be a failing cam position sensor also, to some extent. I goofed on mine in my car and it was causing a wicked extended crank on start. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
Kyblack76 Posted April 28, 2014 Author Report Posted April 28, 2014 Sounds like Egr, I have a 3.8l that one day ran just kjkr that out of the blue. Had a sulfer smell. Was a simple thing called a Egr. Something to do with takeing exhaust through it to make the idel smooth. What happens over time is it get all clogged up with sulfer shit. Don't know for sure if thats it but here is a video that will shoe you what I am talking about. http://www.youtube.com/watch?v=Z07nC6sQ2FI Egr was done on the first day. SEE FIRST post.. Cleaned, then, i bought/installed new one. Hell with mfi, carb it! I can get 4150 manifolds for that engine. No happening in 5 life times...lol My blazer had most of the same problems, a can of MAF sensor cleaner and about half an hour of cleaning it and i was good, all codes cleared themselves and to this day i haven't had another code. It didn't look dirty either, but a 10 dollar can of cleaner its better then replacing all my O2 sensors like the "professional" was telling me Im seeing no MAF triggers, not O2 codes.... Spider rail, and pressure reg is on order all ready. Wont see it till around mid next week........ im confident on THIS repair. Also, ... im not paying for the fuel pump. Not the part, not the labor. Phone call made that official. ... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Tarball Posted April 28, 2014 Report Posted April 28, 2014 Sounds like Egr, I have a 3.8l that one day ran just kjkr that out of the blue. Had a sulfer smell. Was a simple thing called a Egr. Something to do with takeing exhaust through it to make the idel smooth. What happens over time is it get all clogged up with sulfer shit. Don't know for sure if thats it but here is a video that will shoe you what I am talking about. http://www.youtube.com/watch?v=Z07nC6sQ2FI Egr was done on the first day. SEE FIRST post.. Cleaned, then, i bought/installed new one. Hell with mfi, carb it! I can get 4150 manifolds for that engine. No happening in 5 life times...lol My blazer had most of the same problems, a can of MAF sensor cleaner and about half an hour of cleaning it and i was good, all codes cleared themselves and to this day i haven't had another code. It didn't look dirty either, but a 10 dollar can of cleaner its better then replacing all my O2 sensors like the "professional" was telling me Im seeing no MAF triggers, not O2 codes.... Spider rail, and pressure reg is on order all ready. Wont see it till around mid next week........ im confident on THIS repair. Also, ... im not paying for the fuel pump. Not the part, not the labor. Phone call made that official. ... Keep us posted on this... CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
crispy_chick3n Posted May 2, 2014 Report Posted May 2, 2014 Correct me if I'm wrong but wouldn't he have to run a standalone tranny controller too? Or could he use the factory PCM? Off topic.. tranny should be fine as long as he doesnt mess with the cylinder ignition system. you remove the tach signal from the pcm and shit gets fucked up in a hurry. This page is crispy_chick3n approved. © crispy_chick3n inc
Jessica Posted May 2, 2014 Report Posted May 2, 2014 My dad told my a lot of those 4.3 had soft cams. But he also said that smell you had was usually a bad cat. But the cat may be bad because the came is worn out causing shity exhaust and trashing the cats. Just food for thought, Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Kyblack76 Posted May 2, 2014 Author Report Posted May 2, 2014 Work getting done tonight into tomorrow. I'm bringing it home regardless if how or what tomorrow. I'll let ya all know. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
